gen 3 newbee #2817798
09/06/20 12:49 PM
09/06/20 12:49 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
seems like this is the right place to ask im considering going gen 3 hemi dony know anything about them id like to go turbo in a 64 330 dodge race car any pros and cons or places on the web that can steer me in the right direction thanks alot
Re: gen 3 newbee [Re: moparsquid] #2818486
09/08/20 11:12 AM
09/08/20 11:12 AM
K
Kiddart Offline
Kiddart  Offline
K
you are in the right spot. there is also a LX forum out there that has great info. you will love this combo for sure.
Thank you
Kiddart
Re: gen 3 newbee [Re: Kiddart] #2818491
09/08/20 11:42 AM
09/08/20 11:42 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks im looking to it as it something new and im stuck in the stone age
Re: gen 3 newbee [Re: moparsquid] #2818496
09/08/20 11:48 AM
09/08/20 11:48 AM
K
Kiddart Offline
Kiddart  Offline
K
so was I am am going to be putting a turbo on mine this winter so I will be selling my MSDhemi6 and my fast efi system here shortly, I will upgrade to the Mega squirt Gold box or the Holley Terminator X. not sure but i know I have to sell stuff off to buy the new stuff.
Thank you
Kiddart
Re: gen 3 newbee [Re: Kiddart] #2818646
09/08/20 05:03 PM
09/08/20 05:03 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
most likely ill be using the mega squirt my sons can buld thier own and pretty good at tunning
Re: gen 3 newbee [Re: moparsquid] #2832533
10/14/20 12:55 AM
10/14/20 12:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'v been considering going the gen3 route also,what king of power this engines make? Been chasseing after market big blocks to long I'm tried tired
Re: gen 3 newbee [Re: racerx] #2832617
10/14/20 10:43 AM
10/14/20 10:43 AM
K
Kiddart Offline
Kiddart  Offline
K
with a decent set of rods and pistons with stock crank and 12 to 15 pounds of boost it should be at or north of 800hp. the stock cranks are to be said to hold around 1000hp. I am not cashing checks on that but that is what is said.
Thank you
Kiddart
