833 popping out of 4th #2755831
03/25/20 02:00 PM
03/25/20 02:00 PM
St. John's Newfoundland
440newport Offline OP
I have '68 A body 4 speed in my Mirada the last few years. Last summer it started popping out of forth occasionaly only on decelleration and has gradually gotten worse. It isn't quite so bad when the trans is warmed up though.
From what I've read this is likely caused by the center bore of bellhousing being out of alignment with the crank. (I didnt check it for run out at the time, just put it together) WHich may put the input shaft at a slight angle causing wear on the engagement teeth for 4th on the input shaft and/or 3-4 shift collar.
I plan to pull the gearbox and check and fix the bellhosuing alignment if necessary. My question is it likely I'll need parts in the gearbox too? input shaft etc? ANy other thoughts on what it could be? I checked the shift rods alignemnt and it seemed fine, I even tried adding a little more length on the 4th gear shift by taking some from 3rd. but it didn't make a difference that I could tell.
Re: 833 popping out of 4th [Re: 440newport] #2755842
03/25/20 02:18 PM
03/25/20 02:18 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
What I have seen when they are way off is the end of the output shaft wears where the needles ride, the needles, the input bearing, and if ran long enough the input gear and cluster gear polish up pretty good too. You will also see a heavy polish where the pilot bearing rides. A trans that is dialed in looks like new at the pilot bearing. It used to be a big problem with blowproof bells, and early hemi swaps.
Re: 833 popping out of 4th [Re: 4406bbl] #2755866
03/25/20 03:05 PM
03/25/20 03:05 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
How is the shifter linkage, sloppy? Have you tried adjusting it? Before you pull the trans I would try that.
Re: 833 popping out of 4th [Re: 440newport] #2755886
03/25/20 03:38 PM
03/25/20 03:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Most common cause is worn clutching teeth on the 4th (input shaft) and the 3-4 slider. I would first check the obvious shifter linkage adjustments but if it goes in solid but pops out as soon as you let of the gas it probably needs a new input and slider twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 833 popping out of 4th [Re: 440newport] #2755972
03/25/20 06:11 PM
03/25/20 06:11 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Now I'm NOT an engine/trans guy BUT back in 1976-77 my old 340 Cuda 4-speed was doing this. I had a trans guy go through it & said it was the synchros.
Re: 833 popping out of 4th [Re: Sunroofcuda] #2756006
03/25/20 07:47 PM
03/25/20 07:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ That was always the deal back in my T-10 days, usually showed up in 2nd gear first...
Re: 833 popping out of 4th [Re: fourgearsavoy] #2756070
03/26/20 12:19 AM
03/26/20 12:19 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Gus beer
This, if the shifter is correctly adjusted the dog teeth are most likely worn.
Re: 833 popping out of 4th [Re: fourgearsavoy] #2756143
03/26/20 10:59 AM
03/26/20 10:59 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Gus beer
I agree
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 833 popping out of 4th [Re: fourgearsavoy] #2756165
03/26/20 12:01 PM
03/26/20 12:01 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Gus beer
I have a photo to back this up. My transmission (in my 71 Challenger) kept popping out of 4th and I finally got it into my mechanic and this is what he found. I was fortunate in that it didn't damage the trans case but it did require an entire rebuild because of all the metal in the tranny. In my photo, you can see the teeth were wearing against the case when the input shaft was shoved forward. I don't remember all the details as this happened in 1973-74. It cost me almost $200 back then. I now have a great clutch alignment tool though. Get it taken care of as soon as possible. Note on the gear teeth how it was rolling over the edge of the teeth. It is cut back into the gear about 1/4".
Terry
Re: 833 popping out of 4th [Re: 71vert340] #2756265
03/26/20 06:51 PM
03/26/20 06:51 PM
VA
dragon slayer Online content
dragon slayer  Online Content
VA
I have also seen the shifter body bolts come loose and cause issues like this, including not being able to shift.
Re: 833 popping out of 4th [Re: dragon slayer] #2818319
09/07/20 08:30 PM
09/07/20 08:30 PM
Just to update on this...
A few weeks back I jack the car up to pull the gearbox out and see whats going on. After I pull the driveshaft I look up and see one of the trans to bellhousing bolts is missing, and the others are loose. shock
There was almost a 1/4" gap opened up between the bell and trans. I find another 7/16" bolt, tighten them up, stick the driveshaft back in and test drive it. No more popping out of forth.
I should have checked but it didnt even occur to me that it would be something like that.
Now I'm sure the input shaft being at an angle like that didn't do anything any good, but I've been driving it since then a lot and it seems fine so far.
