340 Owners - What spark plugs are you running? #2817603
09/05/20 08:36 PM
09/05/20 08:36 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Interested to learn what brand/type spark plugs you are using in your Mopar - specifically 340 owners / engine builders?
Re: 340 Owners - What spark plugs are you running? [Re: vinnyd76] #2817620
09/05/20 09:33 PM
09/05/20 09:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Bosch Platinum in my 340/6 T/A Challenger (actually 410 cid stroker), running a Mallory Marine YL dual point, mech advance
Re: 340 Owners - What spark plugs are you running? [Re: vinnyd76] #2817641
09/05/20 10:44 PM
09/05/20 10:44 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
autolite 64
cheep and efective !
Re: 340 Owners - What spark plugs are you running? [Re: calrobb2000] #2817658
09/05/20 11:42 PM
09/05/20 11:42 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i still run a set of splitfires ..since I dont run a choke, my other plugs used to foul out all the time when trying to start it..these fire right up.
Re: 340 Owners - What spark plugs are you running? [Re: AARCONV] #2817706
09/06/20 08:44 AM
09/06/20 08:44 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I was a Champion user but switched to NGK's about 4 or 5 years ago and am very happy with them, one is 340 w/ironheads and the other is 416 w/eddy heads
Gary
Re: 340 Owners - What spark plugs are you running? [Re: calrobb2000] #2817716
09/06/20 09:16 AM
09/06/20 09:16 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Originally Posted by calrobb2000
autolite 64
Autolite's are the only ones that seem to last in my 340.
Re: 340 Owners - What spark plugs are you running? [Re: GODSCOUNTRY340] #2817734
09/06/20 10:46 AM
09/06/20 10:46 AM
In a van, down by the river
jmf340 Offline
jmf340  Offline
Autolite 65
Got Mopar???
Re: 340 Owners - What spark plugs are you running? [Re: jmf340] #2817741
09/06/20 11:01 AM
09/06/20 11:01 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Autolite. 64 or 65 - cant remember.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: 340 Owners - What spark plugs are you running? [Re: vinnyd76] #2817797
09/06/20 12:48 PM
09/06/20 12:48 PM
What compression ratio, C.I. and which type heads, stock or aluminum?
Re: 340 Owners - What spark plugs are you running? [Re: Cab_Burge] #2817951
09/06/20 07:01 PM
09/06/20 07:01 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Autolite 64s in an AAR.
Careful, your character's showing!
Re: 340 Owners - What spark plugs are you running? [Re: mopar346] #2817974
09/06/20 08:28 PM
09/06/20 08:28 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
it has been a while since i had a small block.
if i remember correctly i used to run NGK GR4 V power plugs with a MSD 6al ignition system with a blaster coil..
perception is 90% of reality
Re: 340 Owners - What spark plugs are you running? [Re: Cab_Burge] #2817987
09/06/20 09:28 PM
09/06/20 09:28 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the feedback!
Re: 340 Owners - What spark plugs are you running? [Re: Cab_Burge] #2817989
09/06/20 09:29 PM
09/06/20 09:29 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Compression ratio around 10:1, Stock X-Heads
Re: 340 Owners - What spark plugs are you running? [Re: mopar346] #2818019
09/06/20 10:59 PM
09/06/20 10:59 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
When I type in 1970 340 Duster into the search criteria for Auto Zone, they recommend Autolite 65s. Is it just a different temp between the 64 vs 65?
Re: 340 Owners - What spark plugs are you running? [Re: vinnyd76] #2818031
09/06/20 11:25 PM
09/06/20 11:25 PM
new haven ct
K
kcarfanatic Offline
kcarfanatic  Offline
K
new haven ct
53 Autolite. Non-Resistor plug that is no longer available. I bought boxes on them @ Carlisle years ago for a buck a piece. I've used them in bracket engines and street use for decades. 43XLS is the AC equivalent,also a non-resistor,also long out of production.
Re: 340 Owners - What spark plugs are you running? [Re: vinnyd76] #2818039
09/07/20 12:04 AM
09/07/20 12:04 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
yes 64 for long drives warm weather running higher rpm
65 for short trips cold weather lower rpm use
Re: 340 Owners - What spark plugs are you running? [Re: vinnyd76] #2818414
09/08/20 07:27 AM
09/08/20 07:27 AM
mopar346 Offline
mopar346  Offline
I tried both when I first put it together and settled on the 64s, I liked the way they burned better. I'm in Florida and have been known to hammer it.
Re: 340 Owners - What spark plugs are you running? [Re: mopar346] #2819101
09/09/20 09:32 PM
09/09/20 09:32 PM
BDW Offline
BDW  Offline
Anyone ever try E3 plugs, curious if there’s any benefit or just another gimmick.
Re: 340 Owners - What spark plugs are you running? [Re: vinnyd76] #2819161
09/10/20 01:22 AM
09/10/20 01:22 AM
I would run either Champion RN9YC or Autolite # 64 or if you want to run the smaller 5/8 diameter body try their # 3924 twocents
Re: 340 Owners - What spark plugs are you running? [Re: Mr340] #2819230
09/10/20 10:29 AM
09/10/20 10:29 AM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
Gary
What number NGK's do you run and is it up or down from the normal heat range.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
