Page 4 of 4 1 2 3 4
Re: 727 parts for street/strip? [Re: AndyF] #2817943
09/06/20 06:40 PM
09/06/20 06:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As long as you keep the non-LU parts as an assembly i.e. shaft, clutch retainer, support and pump housing, you can use them. Pic below shows the difference in the supports.
Re: 727 parts for street/strip? [Re: John_Kunkel] #2818002
09/06/20 09:58 PM
09/06/20 09:58 PM
A727Tflite Offline
A727Tflite  Offline
The changes between lockup and non are as mentioned, the pump housing never required changes to move from non to lockup.
The only changes for the actual pump from early sixties to end of production, except the 48 was enlargement of pump passages and port timing changes.
The quieting ramps also changed location, style and length but that’s nothing to worry about on the high performance stuff.
Re: 727 parts for street/strip? [Re: John_Kunkel] #2818041
09/07/20 12:07 AM
09/07/20 12:07 AM
AndyF Offline OP
AndyF  Offline OP
On the lock up shaft is that third ball plugging the converter fill port? If so that would be a bad mistake to make to swap parts around.
I looked over the parts I have on the shelf and they look just like the picture. So I put a tag on the lockup part to keep me from using it by accident. The pump bodies appeared to be identical as did the pumps so all of that looks like it can be interchanged. I didn't even know that I had a lock up 727 sitting under the bench until I tore into it. It has been sitting back there for 10 years and I never took a close look at it. I think it came out of a 1978 Cordoba that I parted out years ago. I just pushed the trans under a bench and figured I'd look at it some day. It has a lot of nice looking parts inside so I've been going thru it trying to see what I can use. Looks like I can use most of it except for the input shaft, reaction shaft and valve body.
Re: 727 parts for street/strip? [Re: AndyF] #2818147
09/07/20 12:40 PM
09/07/20 12:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, that's why I recommended keeping the like-year parts together.
Re: 727 parts for street/strip? [Re: hemi-itis] #2818159
09/07/20 01:18 PM
09/07/20 01:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That is an interesting tip. I hadn't heard of the $60 Cummins setup. I'll have to look into that.
Andy,I am waiting for Tom to call me back.I am not sure if the 6 pinion fir without machining anything as it mat be a tad wider.
I could be wrong but I don't think the pressure angle on the splines for the diesel front planetary are the same as 1970 and older which would include push button trans.
Doug
Re: 727 parts for street/strip? [Re: dvw] #2818178
09/07/20 02:26 PM
09/07/20 02:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The diesel pinion carrier is modified by re-broaching the spline angle.
Re: 727 parts for street/strip? [Re: John_Kunkel] #2818251
09/07/20 06:14 PM
09/07/20 06:14 PM
AndyF Offline OP
AndyF  Offline OP
I pulled an older support off the shelf today and looked at it and it only has two passages with one blocked. So this much be another variation. I'm not sure what this support came off of but it is pre-71 since it has the smaller bearing surface for the narrow bushing hub.
Re: 727 parts for street/strip? [Re: John_Kunkel] #2818311
09/07/20 08:08 PM
09/07/20 08:08 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That's what I thought. Not a bolt in.
Doug
Re: 727 parts for street/strip? [Re: justinp61] #2818437
09/08/20 08:58 AM
09/08/20 08:58 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Originally Posted by justinp61
I have a TCS billet steel front drum with the aluminum piston, 15 springs with a billet retainer, billet servos, solid Alto red lined front band, Alto red clutches with Kolene steels. I also removed the governor assembly and made an aluminum spacer to take it's place. Also tapped and plugged the governor feed hole in the park gear.
We did all that the same way but did not dfo the park gear.
What would tgat have done for me?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: 727 parts for street/strip? [Re: 340SIX] #2818456
09/08/20 09:57 AM
09/08/20 09:57 AM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
My understanding is that it stops an oil leak as it's no longer needed to feed the governor.
Re: 727 parts for street/strip? [Re: justinp61] #2818544
09/08/20 01:39 PM
09/08/20 01:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Usually, plugging that hole is only done when using a roller bearing in the rear support; that, along with installing the front sealing ring on the park gear, helps retain the lube pressure that is lost through the rollers.
Re: 727 parts for street/strip? [Re: AndyF] #2821755
09/16/20 11:48 PM
09/16/20 11:48 PM
AndyF Offline OP
AndyF  Offline OP
I decided to build a dolly for the 727 just to make it easier to move around. Went with a three wheel design since I didn't see any reason for the fourth wheel. Seems to work pretty well. A fully loaded 727 rolls around nice and easy on the 5 inch casters.
Re: 727 parts for street/strip? [Re: AndyF] #2821906
09/17/20 02:12 PM
09/17/20 02:12 PM
AndyF Offline OP
AndyF  Offline OP
I've never had a great way to hold the pump housing while working on it so I went ahead and made a tool for the job.
Re: 727 parts for street/strip? [Re: AndyF] #2823637
09/22/20 02:24 PM
09/22/20 02:24 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That's nice holder. I put the pump on top of an empty paint can
Re: 727 parts for street/strip? [Re: 451Mopar] #2823656
09/22/20 03:15 PM
09/22/20 03:15 PM
AndyF Offline OP
AndyF  Offline OP
I wanted to be able to clamp it in a vise so I could use a torque wrench on the bolts. I got tired of wrestling with it so I just made a holder. Should last me forever.
Page 4 of 4 1 2 3 4
