340 Owners - What spark plugs are you running?
#2817603
09/05/20 08:36 PM
09/05/20 08:36 PM
Posts: 1,565 Macomb, MI
vinnyd76
Macomb, MI
Interested to learn what brand/type spark plugs you are using in your Mopar - specifically 340 owners / engine builders?
Re: 340 Owners - What spark plugs are you running?
[Re: calrobb2000]
#2817716
09/06/20 09:16 AM
09/06/20 09:16 AM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
autolite 64
cheep and efective !
Autolite's are the only ones that seem to last in my 340.
[Re: jmf340]
#2817741
09/06/20 11:01 AM
09/06/20 11:01 AM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Autolite. 64 or 65 - cant remember.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: vinnyd76]
#2817797
09/06/20 12:48 PM
09/06/20 12:48 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
What compression ratio, C.I. and which type heads, stock or aluminum?
[Re: mopar346]
#2817974
09/06/20 08:28 PM
09/06/20 08:28 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
it has been a while since i had a small block. if i remember correctly i used to run NGK GR4 V power plugs with a MSD 6al ignition system with a blaster coil..
perception is 90% of reality
[Re: Cab_Burge]
#2817987
09/06/20 09:28 PM
09/06/20 09:28 PM
vinnyd76
Macomb, MI
Thank you for the feedback!
[Re: Cab_Burge]
#2817989
09/06/20 09:29 PM
09/06/20 09:29 PM
vinnyd76
Macomb, MI
What compression ratio, C.I. and which type heads, stock or aluminum? Compression ratio around 10:1, Stock X-Heads
[Re: vinnyd76]
#2818414
09/08/20 07:27 AM
09/08/20 07:27 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
When I type in 1970 340 Duster into the search criteria for Auto Zone, they recommend Autolite 65s. Is it just a different temp between the 64 vs 65? I tried both when I first put it together and settled on the 64s, I liked the way they burned better. I'm in Florida and have been known to hammer it.
Careful, your character's showing!
[Re: Mr340]
#2819230
09/10/20 10:29 AM
09/10/20 10:29 AM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
I was a Champion user but switched to NGK's about 4 or 5 years ago and am very happy with them, one is 340 w/ironheads and the other is 416 w/eddy heads
Gary What number NGK's do you run and is it up or down from the normal heat range.
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
