Re: Tools for cutting fiberglass.
[Re: mopar dave]
#2815323
08/31/20 05:15 AM
08/31/20 05:15 AM
Posts: 2,934 A shed in England
Tig
A shed in England
Looks good
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: mopar dave]
#2815347
08/31/20 07:52 AM
08/31/20 07:52 AM
Tig
A shed in England
Same here, had to make it easier to take on and off. Also on mine, the centre ridge and engine offset really bugs my symmetry OCD
[Re: dOc !]
#2815568
08/31/20 03:33 PM
08/31/20 03:33 PM
Posts: 22,724 Bitopia
jcc
Bitopia
Damn ccj ... you sound VERY WELL VERSED... I coulda used a like you some years back .... But da BOSS would have yur azz over yer politics Thanks maybe? It's good to be the boss, And OP
[Re: Clanton]
#2815788
09/01/20 09:28 AM
09/01/20 09:28 AM
jcc
Bitopia
The self expanding urethane foam is likely the first/easiest choice. But be warned, over filling can wreak havoc, and/or distort the outer surface. Allowing a few vent holes, can reduce that problem, but the the vent holes if left in place, weaken the item you are trying to reinforce.
[Re: CMcAllister]
#2815874
09/01/20 02:05 PM
09/01/20 02:05 PM
Posts: 1 AEFEF
singhharry12
AEFEF
I do have a zig saw and a roto zip. The hole will be rectangular. Some good info here I will have to digest. Fine blade to prevent chips I assume? 9apps cartoonhd
