2013 Dodge Dart Rallye no codes runs rough in open loop
#2812822
08/24/20 09:25 PM
08/24/20 09:25 PM
Posts: 8,146 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
My daughter has a 2013 Dodge Dart Rallye 2.0L automatic. The vehicle has no codes stored and runs rough in open loop on colder starts.... say the first start of the day. It almost seems to be pinging. I cleaned her throttle body and intake temp sensor. I can't hook up to it to read live data as my scan tool is not updated. I thought maybe there was a TSB and that the dealers reprogrammed these? It seems to be that only when the PCM is in open loop it's an issue. I think she has about 80K miles. I added injector cleaner and topped off her tank with high grade fuel. I told her to only run premium, she has not seen improvement yet. Any info/help is appreciated. Thanks
EDIT: Just an FYI I had her take it to the local dealer, she told them I am a Tech, and there were no codes, it only acts up cold and I wanted it reflashed. So they diagnosed it and told her there are no codes (she told them that) and that they want to install new motor mounts for $1000, she can bring it back if that does not fix it.
Re: 2013 Dodge Dart Rallye no codes runs rough in open loop
[Re: UCUDANT]
#2812953
08/25/20 08:23 AM
08/25/20 08:23 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
The first thing I would do is clean the throttle body and do a reset on the PCM. Disconnect the positive battery cable then ground the positive cable end for 30 seconds and restart. It may stall the first time you crank it after that. Simply cycle the key and restart it.
[Re: Guitar Jones]
#2812956
08/25/20 08:28 AM
08/25/20 08:28 AM
Guitar Jones
It may have a thermostat stuck partially open which would lead to a long warm up time. This causes the PCM to add more fuel, over time it ends up being to rich causing the rough running until the O2 takes over.
[Re: Guitar Jones]
#2812964
08/25/20 08:44 AM
08/25/20 08:44 AM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Thanks Guitar Jones I will try to re-clean the throttle body and then do a reset. I'll check the thermostat too.
[Re: UCUDANT]
#2813358
08/25/20 11:47 PM
08/25/20 11:47 PM
Posts: 1,004 ohio
bbtrux
ohio
Stat would likely ( but not always - in diag there is no always) set a P0128 ; you cleaned the T.B. , but no idle relearn, but she drove enough since for it to pick up on it. Suggesting premium was a bad idea. Car doesnt require premium, and when you start the car , first thing it does is wing the timing until it hears spark knock. GM and chrysler both had tsb's for that. Those things being said , i have no answer , but due to the nature , i wonder about cam phasers (potentially cold phaser knock before oil pressure builds) or even simple stuff like shield rattle, due to the described condition being cold start , and sounds like before actually out on the road. never had a spark knock at idle or out of gear, even on the worst sucked magum lower plenum gaskets that had let the engine coke itself up full of crankcase oil . even those cases only had preignition under load.
