Page 2 of 3 1 2 3
Re: De-stroked Hemi possibilities? [Re: A727Tflite] #2812646
08/24/20 03:36 PM
08/24/20 03:36 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I'm pretty sure this question or something like it was asked awhile ago. Bob George answered and I believe he said they were a hand grenade waiting to go off. Could be wrong though on his answer, Im getting old and my wife tells me I cant remember anything. I would check in it further if it was me. Although I like the idea.
Re: De-stroked Hemi possibilities? [Re: A727Tflite] #2812647
08/24/20 03:36 PM
08/24/20 03:36 PM
Minnesota
Hemi_Joel Online content OP
Hemi_Joel  Online Content OP
Minnesota
Any intake, any carb(s), mechanical injection OK. No EFI. Points distributor or magneto only.
Transman, what is the rod journal dia on that 3.48 crank?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812653
08/24/20 03:44 PM
08/24/20 03:44 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'm not sure if you know Ron Flood...............North Branch , Mn. , but soon to be up Pine City way.
I believe he has a set of the B - RB to Hemi conversion heads , and Lord knows what else he has squirreled away , but he might be a good brain to pick for a project like this.
Cedar Machine.( 651 ) 674 - 8365
He is semi retired , but I think he would not be opposed to any project that was cool or interesting , and this sounds like both.
Re: De-stroked Hemi possibilities? [Re: tubtar] #2812663
08/24/20 04:03 PM
08/24/20 04:03 PM
Minnesota
Minnesota
Unfortunately, I know Ron. Never again.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812673
08/24/20 04:21 PM
08/24/20 04:21 PM
A727Tflite Offline
A727Tflite  Offline
Standard B/RB - 2.375” with standard mains - 2.750”.
I also have a longer set of NASCAR rods at 7.06”.
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812692
08/24/20 04:54 PM
08/24/20 04:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I never learn.
Boffin Emeritus
Re: De-stroked Hemi possibilities? [Re: polyspheric] #2812707
08/24/20 05:23 PM
08/24/20 05:23 PM
Minnesota
Minnesota
That's good info to consider, Boff. What is the highest rod/stroke ratio that will still pull hard enuff on the intake to make big power?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812713
08/24/20 05:35 PM
08/24/20 05:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind, I'm sure it will be successful.
Boffin Emeritus
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812718
08/24/20 05:41 PM
08/24/20 05:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Good luck with your project
Boffin Emeritus
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2812761
08/24/20 07:42 PM
08/24/20 07:42 PM
Locomotion Offline
Locomotion  Offline
What about destroking/sleeving a 383/400 with Max-Wedge heads?
Custom/welded intakes allowed?
Re: De-stroked Hemi possibilities? [Re: Locomotion] #2812772
08/24/20 07:57 PM
08/24/20 07:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In the end, I think a destroked hemi....... done without reinventing the wheel...... would likely make as much of more power than anything else you could come up with using factory castings from the competition.
A slightly stroked Boss 351 would also be a good option.
Re: De-stroked Hemi possibilities? [Re: fast68plymouth] #2812796
08/24/20 08:42 PM
08/24/20 08:42 PM
A727Tflite Offline
A727Tflite  Offline
All theory again. Empirical data. We tried a shorter rod versus the production long rod (6.960”) and the short rod lost power
In every situation. In the cas of both these engines it was solid tenth off the mark.
Stick with what works.
Re: De-stroked Hemi possibilities? [Re: Locomotion] #2812797
08/24/20 08:46 PM
08/24/20 08:46 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
MaxWedge Joel just wouldn’t be right... I’d have to change my contact list in my phone then.
69 GTX 68 Road Runner
Re: De-stroked Hemi possibilities? [Re: JERICOGTX] #2812817
08/24/20 09:18 PM
08/24/20 09:18 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Can you move the lifter bores around? The Wescott and Barton stuff all has the lifter bores moved, to straighten out the pushrod geometry. They have done for years.
Alan Jones
Re: De-stroked Hemi possibilities? [Re: Locomotion] #2812840
08/24/20 10:06 PM
08/24/20 10:06 PM
A727Tflite Offline
A727Tflite  Offline
We tried that before the de-stroked Hemi. 361 block. 348 cubic inches, port matched maxwedge heads, single 4 bbl. Ran it way past 8500.
4 speed. I think you would be hard pressed to get close to Hemi power even with state of the art raised port maxies.
Valve train would be easier to sort out on a wedge.
Re: De-stroked Hemi possibilities? [Re: LA360] #2812872
08/24/20 11:07 PM
08/24/20 11:07 PM
Minnesota
Minnesota
Yes that would be legal. Big can core/can bearings ok too
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: JERICOGTX] #2812875
08/24/20 11:09 PM
08/24/20 11:09 PM
Minnesota
Minnesota
You know me well, Jeff! Hemi Joel without a Hemi is like JericoGTX with a powerglide. drive
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2813013
08/25/20 11:01 AM
08/25/20 11:01 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I had a 396 hemi a long time ago in my MP car. It never made the power that I thought, at least on my budget. I was better off with just running the weight to match the cubes.
Re: De-stroked Hemi possibilities? [Re: Hemi_Joel] #2813085
08/25/20 02:00 PM
08/25/20 02:00 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Here's how you do it
You start with a 400 block because you want the B-engine mains. Make two 3/4" thick deck plates to adapt the Hemi heads to the wedge block while simultaneously bringing the deck up to standard RB height. You want that extra deck plate thickness so you have a better angle at grinding clearance for the pushrod in the block valley without hitting water. You also need the extra thickness for addressing the inner head stud mis-match, & oil drainback.
Bore the 400 block & the deck plates to accept sleeves pressed through BOTH the plates & block to get the bore down to 4.25". The cylinder walls will now be super thick & tied together nicely.
Next, take a B-engine crank & destroke/offset grind it down to big block Chevy size on the rods, taking it from 3.375" down to 3.21". This will yield a 364" engine with room to bore/hone during rebuilds.
With a 3.21" stroke, 7.1" rods, & a 10.725" total deck, the pistons can be a convenient stock or near-stock height, but will need a big-*** dome to make any compression. The typical 12.5:1 race hemi pistons might be a cheap route if you can come up with a 7.1" rod to handle the pin end at a price to make them worth it.
There you go, a wedge based 364" Gen II solution that might actually be cheaper than building the real deal. Go forth & go fast.
Re: De-stroked Hemi possibilities? [Re: 73DAD] #2813106
08/25/20 03:01 PM
08/25/20 03:01 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
THE BIGGEST PROBLEM WITH THAT KIND OF RPM IS STABLIZING THE VALVE TRAIN. RAY BARTON AND JESEL ARE NOW GETTING A HOLD OF IT AT 10500. ANYTING MORE THAN THAT I DONT KNOW.
JAKES AUTOMOTIVE
Page 2 of 3 1 2 3
