Re: De-stroked Hemi possibilities?
[Re: A727Tflite]
#2812647
08/24/20 03:36 PM
08/24/20 03:36 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
Any intake, any carb(s), mechanical injection OK. No EFI. Points distributor or magneto only.
Transman, what is the rod journal dia on that 3.48 crank?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2812653
08/24/20 03:44 PM
08/24/20 03:44 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I'm not sure if you know Ron Flood...............North Branch , Mn. , but soon to be up Pine City way. I believe he has a set of the B - RB to Hemi conversion heads , and Lord knows what else he has squirreled away , but he might be a good brain to pick for a project like this. Cedar Machine.( 651 ) 674 - 8365 He is semi retired , but I think he would not be opposed to any project that was cool or interesting , and this sounds like both.
[Re: tubtar]
#2812663
08/24/20 04:03 PM
08/24/20 04:03 PM
Hemi_Joel
Minnesota
Unfortunately, I know Ron. Never again.
[Re: Hemi_Joel]
#2812673
08/24/20 04:21 PM
08/24/20 04:21 PM
Posts: 3,075 Michigan
A727Tflite
Transman, what is the rod journal dia on that 3.48 crank? Standard B/RB - 2.375” with standard mains - 2.750”. I also have a longer set of NASCAR rods at 7.06”.
[Re: polyspheric]
#2812707
08/24/20 05:23 PM
08/24/20 05:23 PM
Hemi_Joel
Minnesota
That's good info to consider, Boff. What is the highest rod/stroke ratio that will still pull hard enuff on the intake to make big power?
[Re: Hemi_Joel]
#2812713
08/24/20 05:35 PM
08/24/20 05:35 PM
Posts: 4,206 New York
polyspheric
New York
Never mind, I'm sure it will be successful.
Boffin Emeritus
[Re: Hemi_Joel]
#2812718
08/24/20 05:41 PM
08/24/20 05:41 PM
polyspheric
New York
Good luck with your project
Boffin Emeritus
[Re: Hemi_Joel]
#2812761
08/24/20 07:42 PM
08/24/20 07:42 PM
Posts: 5,894 Florida
Locomotion
What about destroking/sleeving a 383/400 with Max-Wedge heads? Custom/welded intakes allowed?
[Re: Locomotion]
#2812797
08/24/20 08:46 PM
08/24/20 08:46 PM
Posts: 10,022 MN
JERICOGTX
MN
What about destroking/sleeving a 383/400 with Max-Wedge heads? Custom/welded intakes allowed? MaxWedge Joel just wouldn’t be right... I’d have to change my contact list in my phone then.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2812817
08/24/20 09:18 PM
08/24/20 09:18 PM
Posts: 6,139 Melbourne , Australia
LA360
Can you move the lifter bores around? The Wescott and Barton stuff all has the lifter bores moved, to straighten out the pushrod geometry. They have done for years.
Alan Jones
[Re: Locomotion]
#2812840
08/24/20 10:06 PM
08/24/20 10:06 PM
A727Tflite
What about destroking/sleeving a 383/400 with Max-Wedge heads? Custom/welded intakes allowed? We tried that before the de-stroked Hemi. 361 block. 348 cubic inches, port matched maxwedge heads, single 4 bbl. Ran it way past 8500. 4 speed. I think you would be hard pressed to get close to Hemi power even with state of the art raised port maxies. Valve train would be easier to sort out on a wedge.
[Re: LA360]
#2812872
08/24/20 11:07 PM
08/24/20 11:07 PM
Hemi_Joel
Minnesota
Can you move the lifter bores around? The Wescott and Barton stuff all has the lifter bores moved, to straighten out the pushrod geometry. They have done for years. Yes that would be legal. Big can core/can bearings ok too
[Re: JERICOGTX]
#2812875
08/24/20 11:09 PM
08/24/20 11:09 PM
Hemi_Joel
Minnesota
What about destroking/sleeving a 383/400 with Max-Wedge heads? Custom/welded intakes allowed? MaxWedge Joel just wouldn’t be right... I’d have to change my contact list in my phone then. You know me well, Jeff! Hemi Joel without a Hemi is like JericoGTX with a powerglide.
[Re: 73DAD]
#2813106
08/25/20 03:01 PM
08/25/20 03:01 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
THE BIGGEST PROBLEM WITH THAT KIND OF RPM IS STABLIZING THE VALVE TRAIN. RAY BARTON AND JESEL ARE NOW GETTING A HOLD OF IT AT 10500. ANYTING MORE THAN THAT I DONT KNOW.
JAKES AUTOMOTIVE
