Re: setting timing (cam sync) on 87 318 truck?
[Re: dvw]
#2809453
08/16/20 11:55 AM
08/16/20 11:55 AM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Doesn't an '87 still have an electronic ignition distributor? And adjustable timing? In the repair manual for my old '00 Durango you align the rotor with the #1 cylinder notch in the cam sensor plate with the crank at TDC. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: dvw]
#2809646
08/17/20 04:51 AM
08/17/20 04:51 AM
Posts: 5,927 ohio
ruderunner
ohio
Iirc, unplug the coolant temperature sensor. The 2 wire one for the computer, not the single wire for the gauge.
Also, is he sure the balancer hasn't slipped?
Distributor, oil pump drive installed correctly?
Matching balancer and timing cover?
Angry white pureblood male
[Re: dvw]
#2810141
08/18/20 11:40 AM
08/18/20 11:40 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I used Google to find a bunch of information, pictures and video on how to set my 1999 5.9 Magnum cam sync for initial fire up. After I got it up and running, I used a borrowed Matco Tools scanner to verify the setting, which was almost dead on, but needed some fine tuning. A lot of guys have to go to someone with an expensive scanner to have there's checked, which usually means the dealer. These things are a few decades old now, so a lot of places have no idea how to do it anymore.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2810495
08/19/20 02:18 AM
08/19/20 02:18 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
You don't have a cam sync with a TBI engine only the magnums. You set the initial distributor location the same as you would a carb engine then after it is running and up to operating temp you disconnect the coolant temp sensor. That sets the computer in limp mode. Set your base timing there. Reconnect the coolant temp sensor and cycle the ignition key. It will probably set a code but may not turn on the MIL if you only do it once. Clear the code and you should be good to go. When you set the base timing what you are doing is setting the maximum advance the engine will ever get. The computer retards the timing event controlling the amount of advance.
