https://youtu.be/6j_THRt3UfQLit right up after 3 years like a new car. Gas smelled varnishy but ran fine. Wish there was an easy way to drain the tank other than pulling it. I could pull it and replace with a OEM looking stainless tank. I'll have to change the oil.
Accumulated some parts.
Battery tray package - AMD tray, Hoffman brace and holddown, Frank Badelson cables
Manifolds HP ceramic coated manifold from AndyF with 3" headpipes (nice to have the O2 bung), Hoffmans manifold bolt set
Optima yellow top battery and good Optima charger/trickle charger
Borgeson steering
Custom type II pump mounting brackets
Detroit Speed pump, pulley and hard line
Need to get a small sector box (thats the pitman I have already) and Borgeson universal coupling with the rubber bushing - Mancinis right down the road from me
Trans
Pulling to have Hemi OD gearset installed. THAT WILL ROCK. MAN I'm not looking forward to doing that. May do it tomorrow. Then I'll probably have to get some steeper gears than 3.55's in my 8-3/4.
