BradH #2807952
08/12/20 08:03 AM
08/12/20 08:03 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Haven't seen Brad on in a while. Anyone know if he's still on here?
Re: BradH [Re: mopar dave] #2807962
08/12/20 08:34 AM
08/12/20 08:34 AM
tboomer Online work
tboomer  Online Work
He took some time off to work on his car... whistling
Re: BradH [Re: tboomer] #2808320
08/13/20 08:28 AM
08/13/20 08:28 AM
Mt Morris Michigan
Mt Morris Michigan
Well, i hope he gets it done. Haven't seen him post in a long time. He used a cam in his 470 and that exact same cam was spec'd by Bullet for my 511 and just wanted to ask how it worked out for him.
Re: BradH [Re: mopar dave] #2808324
08/13/20 08:56 AM
08/13/20 08:56 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
He got upset and left. Hasn't been back since February.
Jeff
69 GTX 68 Road Runner
Re: BradH [Re: mopar dave] #2808328
08/13/20 09:02 AM
08/13/20 09:02 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
I let Brad know about this thread, he says the last couple of cams he used were Comp spece'd by Dwayne Porter. Never used Bullet and doesn't have a 470.
Are you sure you are not confusing him with AndyF?
Re: BradH [Re: JERICOGTX] #2808352
08/13/20 10:05 AM
08/13/20 10:05 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Jeff
Not exactly
Re: BradH [Re: Al_Alguire] #2808365
08/13/20 10:38 AM
08/13/20 10:38 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Jeff
Not exactly
All that said, I miss Brads input here, I value his opinion, we both are from the Toy flowbench era . smile I hope he is doing ok
Re: BradH [Re: CSK] #2808369
08/13/20 10:44 AM
08/13/20 10:44 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Jeff
Not exactly
Same.
Last I remember, whe was contemplating taking an employer offered package and moving on to something else. Hope that is going well for him.
Re: BradH [Re: BSB67] #2808380
08/13/20 11:14 AM
08/13/20 11:14 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FYI he was put on hiatus here, he did not leave on his own. I miss Brad's input as well. He is one of us old timers who had been around here since the late 90's.
Re: BradH [Re: Al_Alguire] #2808424
08/13/20 12:43 PM
08/13/20 12:43 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Jeff
Not exactly
I was trying to be nice.
Re: BradH [Re: powertrip] #2808429
08/13/20 12:48 PM
08/13/20 12:48 PM
Mt Morris Michigan
Mt Morris Michigan
No, he pm’d me some flat tappet cams he tried and one was an Ultradyne (Bullet) 267/271@50. Curious how that worked for power in his 470. Bullet spec’’d me this for my 511. It’s going in this off season.
Re: BradH [Re: mopar dave] #2808432
08/13/20 12:55 PM
08/13/20 12:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
As has been said....... he doesn’t run a 470.
It’s an RB 452.
The first combo I dynoed for him had the UD 267/267, which was experiencing some upper rpm stability issues that day.
That cam was never run in the car.
Iirc, 440Jim ran the UD267/267 in the 470 in his Dart.
Re: BradH [Re: fast68plymouth] #2808459
08/13/20 02:11 PM
08/13/20 02:11 PM
NC
440Jim Offline
440Jim  Offline
NC
Yea,
I ran the UD cam. Starting with my 451 CID low deck with Edelbrock RPM heads.
Ultradyne NF63 Cam Specs: 294 @0.020, 267 @0.050, 185 @0.200, 0.609" valve lift
Re: BradH [Re: 440Jim] #2808470
08/13/20 02:40 PM
08/13/20 02:40 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, that cam. What issues did you have with that?
Re: BradH [Re: mopar dave] #2808505
08/13/20 03:48 PM
08/13/20 03:48 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't recall any issues/problems. Here are my notes from 2002:
Crane aluminum roller rockers, 1.5 ratio on Edelbrock RPM heads
Comp Cams 10 degree retainers (#748, 1.5" dia), Isky 8005A valve springs, 140 lb seat, 390 lb open.
Edelbrock heads, 295cfm@0.600", 299cfm@0.700" intake (clean up porting only +10cfm), 228cfm@0.600", 235cfm@0.700" exhaust (some porting +25 cfm)
11.8 CR with 72cc heads, zero deck
2" Pro parts headers (a little long, but not as bad as the Hooker A-body headers).
950 HP carb, Edelbrock TM-6 intake with a little porting
8", 5100 rpm Coan converter (may go 5100-5200 with added CID)
4.56 gear, 30.6" tall tire
3150 lbs race weight
The car ran a best of 10.27 at 129.4 mph in the quarter mile, shifting at 6200 rpm, crossing the line at 6750 rpm.
I tried higher shift points (up to 6800, 0.05 slower) but it ETed the best there.
The sixty foot was 1.40-1.42 with a 6"-12" wheel stand foot braking (no trans brake), so torque at 5100 rpm was good.
The car has Dynomax bullet (straight through) "mufflers", but no tail pipes or cross over.
Re: BradH [Re: 440Jim] #2808551
08/13/20 05:29 PM
08/13/20 05:29 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks Jim. Bullet tells me I can use my current springs which have 135#@1.900 and 430@1.250. Work good with my Comp 270@50 , 180@.200 .644 lift 110lda by Dwayne. This has been a great cam so not sure I will gain any thing going to this cam which is 267@50, 185@.200 on 108 with same lift. I’m also using Titanium retainers. Was really looking for advise on any opinions on these springs or if I need something different and was hoping to hear from Brad about this cam in his 452. Thanks
Re: BradH [Re: mopar dave] #2808681
08/13/20 10:35 PM
08/13/20 10:35 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Seems to be a lot of Brads on here ,but there was a Brad that ran in the Monster Mopar series that runs a 540 could that be him work
Re: BradH [Re: racerx] #2808696
08/13/20 11:38 PM
08/13/20 11:38 PM
Mt Morris Michigan
Mt Morris Michigan
He goes by BradH. He has a challenger.
Re: BradH [Re: Al_Alguire] #2808736
08/14/20 08:20 AM
08/14/20 08:20 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Sadly it seems that in the last few years a lot of the "old timers" have left for one reason or another. I miss the days when Bob George and crew were posting, a lot of knowledge has left here.
Re: BradH [Re: mopar dave] #2808737
08/14/20 08:26 AM
08/14/20 08:26 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Ok.….that's the Brad with the 72-3 challenger with the 5" T/A hood blue with a black vinyl top work
