Gas ported RINGS
#2808693
08/13/20 11:25 PM
08/13/20 11:25 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
very interesting new top Piston ring by Total Seal
Re: Gas ported RINGS
[Re: CSK]
#2808703
08/14/20 12:18 AM
08/14/20 12:18 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
While the vertical gas ports are supposed to be more effective, this is def a nice option for pistons without ports. I wonder if they are slightly lower tension to take advantage of the whole idea.
[Re: Chargerfan68]
#2808768
08/14/20 09:47 AM
08/14/20 09:47 AM
Posts: 3,516 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
While the vertical gas ports are supposed to be more effective, this is def a nice option for pistons without ports. I wonder if they are slightly lower tension to take advantage of the whole idea. Total Seal's tests show these rings make more power without gas ports than engines with gas ports and standard rings.
