Re: BradH
[Re: mopar dave]
#2808324
08/13/20 08:56 AM
08/13/20 08:56 AM
Posts: 10,049 MN
JERICOGTX
MN
He got upset and left. Hasn't been back since February.
Jeff
69 GTX
68 Road Runner
Re: BradH
[Re: JERICOGTX]
#2808352
08/13/20 10:05 AM
08/13/20 10:05 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Jeff Not exactly
Re: BradH
[Re: Al_Alguire]
#2808365
08/13/20 10:38 AM
08/13/20 10:38 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Jeff Not exactly All that said, I miss Brads input here, I value his opinion, we both are from the Toy flowbench era . ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I hope he is doing ok
Re: BradH
[Re: CSK]
#2808369
08/13/20 10:44 AM
08/13/20 10:44 AM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
Jeff Not exactly All that said, I miss Brads input here, I value his opinion, we both are from the Toy flowbench era . ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I hope he is doing ok Same. Last I remember, whe was contemplating taking an employer offered package and moving on to something else. Hope that is going well for him.
Re: BradH
[Re: BSB67]
#2808380
08/13/20 11:14 AM
08/13/20 11:14 AM
Al_Alguire
Las Vegas
FYI he was put on hiatus here, he did not leave on his own. I miss Brad's input as well. He is one of us old timers who had been around here since the late 90's.
Re: BradH
[Re: Al_Alguire]
#2808424
08/13/20 12:43 PM
08/13/20 12:43 PM
Posts: 10,049 MN
JERICOGTX
MN
Jeff Not exactly I was trying to be nice.
69 GTX
68 Road Runner
Re: BradH
[Re: mopar dave]
#2808432
08/13/20 12:55 PM
08/13/20 12:55 PM
fast68plymouth
So. Burlington, Vt.
Curious how that worked for power in his 470 As has been said....... he doesn’t run a 470. It’s an RB 452. The first combo I dynoed for him had the UD 267/267, which was experiencing some upper rpm stability issues that day. That cam was never run in the car. Iirc, 440Jim ran the UD267/267 in the 470 in his Dart.
Re: BradH
[Re: mopar dave]
#2808505
08/13/20 03:48 PM
08/13/20 03:48 PM
Posts: 16,932 NC
440Jim
NC
Yes, that cam. What issues did you have with that? I don't recall any issues/problems. Here are my notes from 2002: Crane aluminum roller rockers, 1.5 ratio on Edelbrock RPM heads Comp Cams 10 degree retainers (#748, 1.5" dia), Isky 8005A valve springs, 140 lb seat, 390 lb open. Edelbrock heads, 295cfm@0.600", 299cfm@0.700" intake (clean up porting only +10cfm), 228cfm@0.600", 235cfm@0.700" exhaust (some porting +25 cfm) 11.8 CR with 72cc heads, zero deck 2" Pro parts headers (a little long, but not as bad as the Hooker A-body headers). 950 HP carb, Edelbrock TM-6 intake with a little porting 8", 5100 rpm Coan converter (may go 5100-5200 with added CID) 4.56 gear, 30.6" tall tire 3150 lbs race weight The car ran a best of 10.27 at 129.4 mph in the quarter mile, shifting at 6200 rpm, crossing the line at 6750 rpm. I tried higher shift points (up to 6800, 0.05 slower) but it ETed the best there. The sixty foot was 1.40-1.42 with a 6"-12" wheel stand foot braking (no trans brake), so torque at 5100 rpm was good. The car has Dynomax bullet (straight through) "mufflers", but no tail pipes or cross over.
Re: BradH
[Re: Al_Alguire]
#2808736
08/14/20 08:20 AM
08/14/20 08:20 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
FYI he was put on hiatus here, he did not leave on his own. I miss Brad's input as well. He is one of us old timers who had been around here since the late 90's. Sadly it seems that in the last few years a lot of the "old timers" have left for one reason or another. I miss the days when Bob George and crew were posting, a lot of knowledge has left here.
