Re: BradH [Re: mopar dave] #2808738
08/14/20 08:29 AM
08/14/20 08:29 AM
NC
440Jim Offline
440Jim  Offline
NC
My 2-cents,
Those springs should be OK if the seat pressure is still as advertised.
I would gear for keeping the RPM below 6800, especially trying to control the valves with 1.6 rockers.
My "extreme" flat tappet springs would be 150 seat, 440 open. But that is starting to push things for durability on the lifters.
Re: BradH [Re: racerx] #2808747
08/14/20 08:48 AM
08/14/20 08:48 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yes, i believe so.
Re: BradH [Re: 440Jim] #2808748
08/14/20 08:52 AM
08/14/20 08:52 AM
Mt Morris Michigan
Mt Morris Michigan
Last time at the track i was going thru the traps at 7050 and would get a pop out of the engine once in a while. Thought i may have been tickling the rev limiter which was set at 7100, i now am thinking that the valves were barely under control at that rpm. not sure, but i know my shift points will be below 6500 this time out. I may have to run 1/8 mile only. Will see. Thanks
