Re: Dakota not dead? A followup.........
[Re: I_bleed_MOPAR]
#2820380
09/13/20 08:23 PM
09/13/20 08:23 PM
Posts: 16,813 Between Houston & Galveston TX
SattyNoCar
Geez, been over a month already.......... BUT, its not like I'm working on it everyday. At this point, I've got about 7 hours into it. I didn't buy the shrinking disc (yet) but I did buy the finest body working tool set Harbor Freight has to offer (re: the only one). I'm REAL close now. I'm not expecting perfection, but I want to use as little bondo as possible. The way it sits now, I should be able to get the window back in, but before I do that, I want to try to minimize the high and low spots on the roof. I may just try to slowly work with heating/cooling the areas. This: To this: It's not as rough as it looks, my sanding didn't get off all five layers of paint. I made the window plug to not only close the back window, but to monitor the curve of the opening as I work the roof. I know if I used the actual glass I'd either drop it, or drop something on it. Hopefully one more weekend.
John
[Re: Neil]
#2822761
09/19/20 10:02 PM
09/19/20 10:02 PM
SattyNoCar
I carefully used some heat today trying to get out a couple of oil can spots and ended up chasing one all over the back of the roof. Its still there but not as bad as it was. Lacking a real cut off wheel, I bought some cutting discs for my Dremel to cut the inner structure. That was a waste of time and money......"Ziii *SNAP*Ziiiii *SNAP" Honestly, I was worried that with a real cutter, I'd end up going thru the outer roof too, so I did the best I could with it in place. Doesn't look too bad out in the sun...... But, get it inside under a shop light.......... I've got it to where I can put the window back in, so I may do final shaping with
John
[Re: SattyNoCar]
#2822765
09/19/20 10:16 PM
09/19/20 10:16 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Lacking a real cut off wheel, I bought some cutting discs for my Dremel to cut the inner structure. That was a waste of time and money......"Ziii *SNAP*Ziiiii *SNAP" I bought larger thicker wheels for my Dremel at Carlisle some years ago - they work great on sheet metal. Just have to let the dremel cool down now and then
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#2822769
09/19/20 10:27 PM
09/19/20 10:27 PM
SattyNoCar
Lacking a real cut off wheel, I bought some cutting discs for my Dremel to cut the inner structure. That was a waste of time and money......"Ziii *SNAP*Ziiiii *SNAP" I bought larger thicker wheels for my Dremel at Carlisle some years ago - they work great on sheet metal. Just have to let the dremel cool down now and then I wasn't aware there were thicker discs available. I'll have to look online.
John
[Re: BSharp]
#2822812
09/20/20 07:42 AM
09/20/20 07:42 AM
SattyNoCar
These wheels are fiber-reinforced. Much more durable than the plain ones, but still not what you'd call heavy-duty. Hmmmm....if that's the only difference, then that's what I was using. They didn't seem noticeably thicker than the regular ones.The disc wasn't shattering, it was breaking around the mounting point. The mounting screw isn't long enough to use washers to reinforce the disc. Wonder if I have the wrong bit?
John
[Re: SattyNoCar]
#2822953
09/20/20 03:39 PM
09/20/20 03:39 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Lookin' good, John. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: larrymopar360]
#2823097
09/20/20 10:17 PM
09/20/20 10:17 PM
Posts: 70,126 Here
DirectSubjection
Here
I use reinforced 1.5" wheels that are 1/16" thick. They work great, just have to let the wheel do the cutting.
