The ole family truckster still getting better #2807220
08/10/20 11:32 AM
08/10/20 11:32 AM
Las Vegas
Al_Alguire Online laugh2 OP
Las Vegas
My son took the long car out again to a TNT at LVMS, all they do these corona days we are in and made some more progress. Still has a vacuum leak only making 3.5" at the stripe and the converter is still tight but some tuning and shift cycling has netted another new best. DA was 5100' barometer 27.7 and 98 degrees but keeps going the right direction. We shall see just how fast this dumptruck motor is eventually
Re: The ole family truckster still getting better [Re: Al_Alguire] #2807228
08/10/20 11:42 AM
08/10/20 11:42 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
WOW …. nice light !
....BAD A$$ STREET CAR.....
Re: The ole family truckster still getting better [Re: Al_Alguire] #2807322
08/10/20 02:52 PM
08/10/20 02:52 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
As always, excuses to go along with a trip to the track. Does anyone make perfect runs ?
Re: The ole family truckster still getting better [Re: PETE@BESTMACHINE] #2807607
08/11/20 10:25 AM
08/11/20 10:25 AM
Las Vegas
Las Vegas
No excuses just facts. Getting better each time he takes it out, sorry if looking at the data and interpreting it bothers you. I am not there and he sends me the info later, suppose I can leave out the details to make you feel better. There is not really any bracket racing in Vegas so the occasional test and tune will have to suffice for now so why not make changes and chase numbers, he is learning what does and does not work. One day this virus stuff will be over hopefully and life can get closer to normal and he can go racing for real again. As for a perfect run yep I am sure they exist and what's wrong with trying to get there shruggy
Re: The ole family truckster still getting better [Re: Al_Alguire] #2807630
08/11/20 11:43 AM
08/11/20 11:43 AM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Al is this still the Cuda? I am still in love with that car! Post a current pic, I for one would love to see it again. I too can only dream of the day I run down the LVMS one more time! We had a blast back in the day amigo! Hope all is well with you and the family.
Diego
Re: The ole family truckster still getting better [Re: n20mstr] #2807631
08/11/20 11:43 AM
08/11/20 11:43 AM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Originally Posted by n20mstr
WOW …. nice light !
Re: The ole family truckster still getting better [Re: Diego_Ted] #2807632
08/11/20 11:46 AM
08/11/20 11:46 AM
Las Vegas
Las Vegas
Ted no my sons engine on a stick.
Re: The ole family truckster still getting better [Re: Al_Alguire] #2807640
08/11/20 12:03 PM
08/11/20 12:03 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
So where is my cuda? LOL
Ted
Re: The ole family truckster still getting better [Re: Al_Alguire] #2808325
08/13/20 08:57 AM
08/13/20 08:57 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Al, pretty impressive for a dump truck motor. Can you refresh my memory as to what the combo is, I might have to get rid of the R-M in my stick. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: The ole family truckster still getting better [Re: BANDIT] #2808368
08/13/20 10:43 AM
08/13/20 10:43 AM
Las Vegas
Las Vegas
quote=BANDIT]Al, pretty impressive for a dump truck motor. Can you refresh my memory as to what the combo is, I might have to get rid of the R-M in my stick. Jim. [/quote]
Well due to the block woes I ended up buying someone's old 600-13 engine and freshened it up basically. It started life in a TS car years ago on a couple kits. I bought it becuase it was a good deal ad came with a bunch of extras, two intakes, carbs, stainless headers, Abruzzi convertrs etc. I was also tired of waiting for a block for the B1 stuff we hurt. It was originally purchased from Indy cylinder head. It is the smaller 425 version of the 600-13 head. Pistons are the nitrous design, top ring land a fair ways down the piston, and a large pin 7.1" rod. Compression is 13.34-1. Cam is a nitrous friendly grind as well on a 119lsa .490/.475 lobe. Indy block obviously 4.563" bore. I had to have the pistons coated and sent them to Line to Line to take up some of the extra bore clearance. First time I have ever used them and other than the unique break in procedure am happy with it so far. Had to make a torque plate as no one had one in our area and BHJ was a long way out. Heads were just given a fresh valve job and rockers rebuilt. New springs, and rods were tossed at it as well. I sent the single 4 intake to Brett Miller to have him work his magic. The manifold came back and looked awesome and was a god deal lighter too smile Carb is a Braswell 2.200 throttle bore piece and has a 2" spacer on it as well
The dyno was a gong show. I used a local shop in Vegas that had never dynoed a Mopar apparently. The shop owner does alot of chassis dyno work and builds a lot of LS stuff but rarely uses the engine dyno. They are friends with my son and he does some body and paint work for them. Kind of a one stop sort of shop. Anyway after a few days of messing around we finally got it on the dyno and ready to run. It was an older superflow that had a fair share of software issues. The dyno sheet really have nothing on it that made any sensse other than a HP and TQ number. BFSC was way outta whack( like reading .023 to .121, AFR's from 0-16.82, lb/hr of fuel from 4.3 to 51.9, VE from 6.4-7.7 just no useful info other than the oil pressure gauge mounted on it that was 77 the entire time(which it is in car too now). Si when I got "numbers" for HP/TQ I was quite skeptical. having never built or been around a 600-13 deal was not sure what to expect. It showed 1080/960, but again I had zero faith in that. I really expected the car to maybe go mid 4.70's/7.50's in decent Vegas air at best, like the fall. For it to run as well as it is I am truly impressed with it so far. Do I think it makes 1080, ehhh not so sure on that. Always hard to convert Vegas to sea level conditons, yes we do the calculation and when you put that into something like Wallace its close, but dont know the exact weight of the car. He weighed it before I left but it was not totally together yet and I took the scales with me when I moved to Ohio. It was 1860 with the B1 in it. He did change a few things in the car to lighten it but then we also put a heavier wheel and tire combo on it. So my guess is with the -15 suit, helmet, his pour in seat, a couple missing panels that were off, no fuel, water or oil in it, a few new racepak things that it is probably 1830-40 now. But that's just a guess until he gets it on some scales race ready
Re: The ole family truckster still getting better [Re: Al_Alguire] #2808914
08/14/20 03:59 PM
08/14/20 03:59 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Re: The ole family truckster still getting better [Re: Al_Alguire] #2809442
08/16/20 11:34 AM
08/16/20 11:34 AM
NC
440Jim Offline
440Jim  Offline
NC
I always like when somebody make a new best with their car. Nice !
5,100 ft DA and 98 degrees. Hopefully the humidity was low (for the driver and crew).
I dislike the 90 degrees and high humidity here in the south east. But 98 sounds uncomfortable... cool
Re: The ole family truckster still getting better [Re: 440Jim] #2809659
08/17/20 07:29 AM
08/17/20 07:29 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I must have missed it, but how big is the Engine Al? Very nice run.
Jeff
69 GTX 68 Road Runner
Re: The ole family truckster still getting better [Re: 440Jim] #2809673
08/17/20 09:31 AM
08/17/20 09:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
98 in Vegas.... that means the sun was down, but wait!! There’s more!! ....now you get baked from the ground. LVMS is a sea of unshaded asphalt and you can see ground temps in the 140+ range. I’m betting the lack-o-humidity was in the low teens..... if your into drinking gallons of water and never going to the bathroom.... summer time racing in the desert is for you! It sucks, but imho not as bad as humidity ever!
