Re: Max clearance with hyper pistons 5-.00 [Re: madscientist] #2807076
08/09/20 09:55 PM
08/09/20 09:55 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Call United Engine & Machine, they manufacture KB hyper pistons, Icon forged pistons and Silvolite pistons. 1-800-648-7970 ext. 159. They can tell you what can and cannot be done with linetoline coatings.And exactly how much clearance you should run on KB hyper pistons.
Re: Max clearance with hyper pistons 5-.00 [Re: madscientist] #2807085
08/09/20 10:16 PM
08/09/20 10:16 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Originally Posted by madscientist
Originally Posted by poboyengineering
Originally Posted by 80fbody
Have a short block with similar situation. Thought about having the pistons coated since they are new and came with the shortblock. Likely to crack/collapse the skirts on those style pistons with too much piston slap.
This is what I'm afraid of since they are pretty brittle.This block was from a dirt track racer, and it has 8 sleeves and they measure 4.005, pistons at 3.993. The pistons are new, and the block just needs a quick hone.
Just CALL Line2Line and TALk to them. The coating they make and use is NOT like other coatings. They can easily make up that clearance and the pistons will fit better than if you bought new pistons and sized them.
It’s not like a regular coating. Don’t make this harder than it is.
What does the process cost?
Kevin
Re: Max clearance with hyper pistons 5-.00 [Re: Twostick] #2807157
08/10/20 07:34 AM
08/10/20 07:34 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
My concern with having mine coated to take up alot of clearance is that over time it must wear off and clearance would be great enough to break them anyways. Opting for new pistons and will probably try to recoup some money by selling the new/old ones.
