I agree - simply beautiful work! If you don't mind me asking, will you coat it with anything to prevent corrosion? If so, with what? Or, is it good to go the way it is? Rob
A final polish and few coats of Carnuba Wax.
I have to put on sweat pants and a nice soft T Shirt to clean the one in the Car now. As I will be climbing all over the fenders and header.
And have to pull the distributed out the motor, and the cross member off so as to drop the transmission down enough to clean it as well. I will use Speedy All Metal. Followed by Wax. The water beads off good enough.
