Max clearance with hyper pistons 5-.00 #2806036
08/07/20 07:59 AM
08/07/20 07:59 AM
pennsylvania
poboyengineering Offline OP
pennsylvania
I have a set of KB107 pistons and their website says. 001-0045 p/w clearance. My block
will give me. 008. How loose can they be run?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806038
08/07/20 08:02 AM
08/07/20 08:02 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Have a short block with similar situation. Thought about having the pistons coated since they are new and came with the shortblock. Likely to crack/collapse the skirts on those style pistons with too much piston slap.
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806090
08/07/20 10:43 AM
08/07/20 10:43 AM
Washington
madscientist Offline
Washington
Line2line coating is what you want.
Re: Max clearance with hyper pistons 5-.00 [Re: madscientist] #2806107
08/07/20 11:32 AM
08/07/20 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With that much clearance you are asking a lot for a coating.. I had 1 set of pistons coated and they
wouldnt guarantee any with that much.. most they would go was .004.. I ran that engine on the
loose side.. it had piston slap when cold but as it heated up it would get better
wave
Re: Max clearance with hyper pistons 5-.00 [Re: MR_P_BODY] #2806143
08/07/20 01:10 PM
08/07/20 01:10 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I think .008" is way too much. I've done coatings to pick up a little but only .001"-.002" and to be honest i'm not sure it was a big help. catalog states minimum clearance at .0015". hyper's don't grow like forged do. depending on the usage i'd probably do .0025"-.0030".
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806176
08/07/20 02:35 PM
08/07/20 02:35 PM
A727Tflite Offline
A727Tflite  Offline
Follow the piston manufacturers suggested clearance specs.
As for Lins2Line, call them, I think they will tell you they can help you. I had .004” added to my pistons and no problems.
Re: Max clearance with hyper pistons 5-.00 [Re: 80fbody] #2806185
08/07/20 02:56 PM
08/07/20 02:56 PM
pennsylvania
pennsylvania
This is what I'm afraid of since they are pretty brittle.This block was from a dirt track racer, and it has 8 sleeves and they measure 4.005, pistons at 3.993. The pistons are new, and the block just needs a quick hone.
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806193
08/07/20 03:22 PM
08/07/20 03:22 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
That be a no go.
I run some hard at .003 on cold assembly and they rattle like old trw-s.
Id think at your specs if you run it hard your gonna be crackin skirts.
The low end forged are not much more then a new set of hypers these days. $100 diff.
The lower end icon forged is what im talking about.
STOP POTATO HATE!
Re: Max clearance with hyper pistons 5-.00 [Re: Mr PotatoHead] #2806242
08/07/20 06:12 PM
08/07/20 06:12 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Way too much clearance. I would find another block or buy new pistons. Those pistons have a short skirt to begin with and .008 clearance they would rock really bad. Even in a hot motor. Like potatohead said that is a no go.
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806475
08/08/20 09:56 AM
08/08/20 09:56 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
She is going to be a knocker... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Max clearance with hyper pistons 5-.00 [Re: racerhog] #2806490
08/08/20 10:30 AM
08/08/20 10:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Years ago I would run nylon buttons to reduce piston slap in conditions like yours
but I havent heard of guys using buttons in a long time.. I would think some still use
them shruggy
wave
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806567
08/08/20 02:03 PM
08/08/20 02:03 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
One of the advantages of the KB piston is that it has a stable expansion rate, it does not expand very much when it gets hot. This allows a smaller running clearance, less piston rocking in the bores, and better ring seal. But the silicone in the alloy does make them brittle, they do not like detonation, and I think they would not like to be slapping around in a bore as well. I know that if they are run loose you will sacrifice some ring seal. I know it is tempting to save a few bucks, but just do it right, if the block is good enough to use, buy pistons to fit, if the block is questionable get a different one and bore it to fit the pistons. You will be much happier in the long term.
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806608
08/08/20 03:50 PM
08/08/20 03:50 PM
Are you feeling lucky?
Are you willing to loose a block over not knowing how much is to much clearances on those type pistons work tsk twocents
Re: Max clearance with hyper pistons 5-.00 [Re: Cab_Burge] #2806693
08/08/20 08:52 PM
08/08/20 08:52 PM
pennsylvania
pennsylvania
No, I'm not willing to sacrifice this block on an experiment, hence my question.
I appreciate the advice, but it seems to bring up a couple of more.
Since the block is 4.005, will I be able to get pistons that aren't under 4.000?
Or, since this has 8 sleeves, can they be bored? I don't mind going 4.030 if needed.
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806707
08/08/20 09:43 PM
08/08/20 09:43 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
If the bores are straight and true, lots of companies make custom pistons for what ever size you want. A lot of the companies will take a stocking shelf piston and machine it to a slightly bigger bore for a minimal charge. I do it all the time with Ross pistons with deck height changes. Call them
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806755
08/09/20 08:28 AM
08/09/20 08:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You could call a few piston companies and ask what is the max bore allowed for their piston
before you change the bore calls are cheap and could be quick
wave
Re: Max clearance with hyper pistons 5-.00 [Re: MR_P_BODY] #2806766
08/09/20 09:16 AM
08/09/20 09:16 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you can buy another set of kb107's in .020" or .030" for less than $300 dollars. that's cheap! so why waste time and money with custom pistons if the KB's will work?
Re: Max clearance with hyper pistons 5-.00 [Re: lewtot184] #2806769
08/09/20 09:34 AM
08/09/20 09:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No way would I go with a set of custom pistons.. why go that way when you bought a set
of inexpensive ones to begin with.. you might end up going .020 over KBs but then
you would need a bore job if the block allows it
wave
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2806870
08/09/20 01:58 PM
08/09/20 01:58 PM
Boise
Moparteacher Offline
Boise
Your block is at 4.005 now. With a .02" over piston the bore would need to be enlarged by approximately .015". That's .0075 of material removed from the wall. That's equivalent to two sheets of writing paper. All this assuming you stay with the clearance machined into the new pistons and don't require any additional clearance at 4.02". I highly doubt that .0075" removed from the liners would be too much, but you can always have it checked prior to machining.
Re: Max clearance with hyper pistons 5-.00 [Re: poboyengineering] #2807066
08/09/20 09:30 PM
08/09/20 09:30 PM
Washington
Washington
Just CALL Line2Line and TALk to them. The coating they make and use is NOT like other coatings. They can easily make up that clearance and the pistons will fit better than if you bought new pistons and sized them.
It’s not like a regular coating. Don’t make this harder than it is.
