Re: Decarbon running engine? [Re: 360view] #2806374
08/08/20 12:14 AM
08/08/20 12:14 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Originally Posted by 360view
Mopar’s official brown foaming spray has worked very well for me, including on heavily carbon’ed up EGR passageways.
It makes a huge cloud of black smoke.
https://www.morris4x4center.com/mopar-combustion-chamber-cleaner-13-oz-aerosol-can-4318001ad.html
I used a can of this on my old Ramcharger to try to get it to pass the NOx emissions when they added that in the DFW area. It cleaned up the piston tops well from what I could see through the spark plug holes. You might have to put in new plugs after cleaning it out.
Floyd Lippencott IV
Re: Decarbon running engine? [Re: mr_340] #2806443
08/08/20 08:20 AM
08/08/20 08:20 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
GM top engine cleaner would dissolve the carbon balls on the old Chevy Citation 4 cyl engines. It would rattle like ball bearings were in the combustion camber. I`m not sure if it is still available.
Re: Decarbon running engine? [Re: mopars4ever] #2807282
08/10/20 01:45 PM
08/10/20 01:45 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I knew guys to pour a can of this down a carb with the engine running...mad science!
https://www.bonami.com/product/bon-ami-powder-cleanser/
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Decarbon running engine? [Re: astjp2] #2807394
08/10/20 05:58 PM
08/10/20 05:58 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Back in the 70's I saw a guy dump Bon Ami down the carb to get the rings to seal and the engine to stop smoking. I thought he was nuts, but it worked. I don't know about using it to clean carbon out.
Re: Decarbon running engine? [Re: elmor353] #2807405
08/10/20 07:00 PM
08/10/20 07:00 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I watched guy at wrecking yard pour water in one although it worked well the bottom of the motor exited the block
NS1AAR
Re: Decarbon running engine? [Re: ns1aar] #2807533
08/11/20 12:32 AM
08/11/20 12:32 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Gently guys GENTLY tsk
I’ve CLEANED UP two high mileage motors using water injection.... Spearco brand ....
Re: Decarbon running engine? [Re: dOc !] #2808079
08/12/20 01:00 PM
08/12/20 01:00 PM
Alberta Canada
PossessedDuster Offline OP
Alberta Canada
Well I didn't try the trans fluid yet but going through my old chemicals I found a can and a half of Ford Motorcraft "Tune-up Cleaner" which is similar I think to the Mopar combustion chamber cleaner. Ran both cans through and got a little smoke nothing too wild. Checked with the borescope after, the tops of the pistons are probably 75% clear but I can see parts of the combustion chamber on the head are still a bit thick. Also with the exhaust vlve open its pretty chunky in the passage for what I could see. m Still wants to ping a but under WOT but not as bad. Maybe another dose of something and a good hour on the highway might sort it out.
Re: Decarbon running engine? [Re: PossessedDuster] #2808157
08/12/20 04:36 PM
08/12/20 04:36 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
For valve cleaning this seems to work well
BMW recommends it
https://www.amazon.com/Liqui-Moly-Ventil-Sauber-Cleaner/dp/B00295G91S
