Re: Cordoba 11.7" Brake Upgrade Worth It?
[Re: gzig5]
#2805885
08/06/20 06:39 PM
08/06/20 06:39 PM
Posts: 22,697 Bitopia
jcc
Bitopia
The larger diameter rotor will help with repeated stops because it has more mass to absorb and dissipate the heat and prevent fade. But, the standard rotor is probably large enough to create enough torque to slow the car quickly or lock up the tires. At least a couple times before fade sets in. I think unless you are doing auto-X or a lot of rapid deceleration, brake fade probably isn't an issue. A good set of performance tires will make a world of difference in stopping distance and contribute to better handling. Other suspension components will affect it, it has to work together as a system. For the few hundred bucks to upgrade to the larger rotors, I think it is worth it but probably isn't going to change your life. Brakes stop the wheels, tires stop the car.
[Re: jcc]
#2805906
08/06/20 07:59 PM
08/06/20 07:59 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
The larger diameter rotor will help with repeated stops because it has more mass to absorb and dissipate the heat and prevent fade. But, the standard rotor is probably large enough to create enough torque to slow the car quickly or lock up the tires. At least a couple times before fade sets in. I think unless you are doing auto-X or a lot of rapid deceleration, brake fade probably isn't an issue. A good set of performance tires will make a world of difference in stopping distance and contribute to better handling. Other suspension components will affect it, it has to work together as a system. For the few hundred bucks to upgrade to the larger rotors, I think it is worth it but probably isn't going to change your life. Brakes stop the wheels, tires stop the car. I didnt mention that I have done upgrades to the suspension and steering. FF stage 3 steering box, poly bushings, 1.06" FF torsion bars, and Bilstien shocks all around. Tires are Cooper Cobras. I just want to know if this would clear 15" magnum 500's and if there is any appreciable difference in the stopping distance under standard driving conditions...not auto track. My front end is also a little lighter than stock with the aluminum goodies (master cylinder, heads, radiator) and Sanden compressor under the hood.
[Re: cjskotni]
#2805923
08/06/20 09:07 PM
08/06/20 09:07 PM
jcc
Bitopia
You have a very nice balanced upgrade package IMO at this point , and to answer your question, I think a good pad/fluid might be the only upgrade to be considered, again at this point. based on bang for buck.
[Re: jcc]
#2806120
08/07/20 12:03 PM
08/07/20 12:03 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I run the 11 3/4' Police/Taxi rotors on both my A & E Body cars along with the Dr Diff Econo rear brake kits. One is power assist the other is manual. Together they make for a nicely proportioned braking package with no need for an adjustable proportioning valve.
One of the best front brake pads I have found are available from Firmfeel. They work very well cold and hot, are not too hard on the rotors and are priced reasonably.. I also use a 475 degree rated DOT 4 brake fluid in both cars.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2806166
08/07/20 02:12 PM
08/07/20 02:12 PM
Posts: 4,449 Michigan
MarkZ
Worthy
Worthy
Made the swap two years ago. The difference using the same factory style calipers was pretty substantial. Car has 255 tires on the front.
[Re: MarkZ]
#2806178
08/07/20 02:42 PM
08/07/20 02:42 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Although I haven't driven or raced the car yet, I've made the swap to the 11.75 rotors... basically because of the larger mass to dissipate heat on road coarse events (HPDE, HSAX)... hoping this will be noticeable and worth the changeover, as well. Otherwise, for many past years (since I've owned the car from 1975)... I used the stock diameter 10.75" front rotors and they weren't bad on HPDE/HSAX events.. choice of good pads makes a difference. For normal street/highway and pylon AX events, the 10.75 rotors worked just fine... again choice of good pads makes a difference... I've typically used Wagner (which is what Dr Diff also supplies within their packaging, but I'm not certain of that).... better choice is anything Police/HD for spirited driving, regardless of brand.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2806617
08/08/20 04:25 PM
08/08/20 04:25 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I've upgraded my '73 Dart's stock discs 10.5"(?) to '73 C-body 11.75" and 1.25" thick rotors and C-body calipers. Been screwing around a year with the wrong MC (1") where braking wasn't 'that' impressive', until I installed a 15/16" MC after which things got a lot better. But I was still driving around with old brake pads. After I installed a set of Hawk HPS brake pads, the braking improved enough to my liking.
EDIT: I have no back-to-back comparison between the old stock rotors and the larger/thicker C-body rotors. The old brake system needed just about everything replaced and I rather install parts I already had on the shelf, and was an upgrade at the same time.
