Page 38 of 48 1 2 36 37 38 39 40 47 48
Re: Modern Bullitt build [Re: SattyNoCar] #2837104
10/24/20 09:46 PM
10/24/20 09:46 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by Satilite73
Would you happen to have any part numbers?
I saw in your facebook link where you bought them, but I'm not 100% clear on what you bought.
I'm looking at #'s 15093 and 15094. Are these what you used?
Thanks!
I think you left one digit out of your classic industry part #
153093 & 153095
Re: Modern Bullitt build [Re: Keepat] #2837322
10/25/20 03:38 PM
10/25/20 03:38 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
You're right, I did. blush
BTW 153095 is a radiator support for a '78 Chevy......... biggrin
We're both doin' good with numbers. laugh2
Appreciate the reply! up
John
Re: Modern Bullitt build [Re: SattyNoCar] #2837369
10/25/20 06:44 PM
10/25/20 06:44 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Oops, I did get it right once ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2839394
10/30/20 05:56 PM
10/30/20 05:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Bullitt tags for the Bullitt Charger :-)
Re: Modern Bullitt build [Re: Keepat] #2841042
11/03/20 12:40 AM
11/03/20 12:40 AM
Superfreak
Superfreak
Absolutely beautiful!!! drool
Re: Modern Bullitt build [Re: ] #2862107
12/19/20 12:22 PM
12/19/20 12:22 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
To get the hood clearance for the 1968 hemi air cleaner I had to make a custom base and air filter. Started with a cardboard template before making it out of 1/8” aluminum plate.
I think the 1” velocity stacks worked well.
Thanks and happy holidays!
Pat
Re: Modern Bullitt build [Re: Keepat] #2862232
12/19/20 05:47 PM
12/19/20 05:47 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - as always excellent porn!
What is the filter media?
Re: Modern Bullitt build [Re: larry4406] #2862463
12/20/20 09:40 AM
12/20/20 09:40 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
K&N and UNI foam, 1st layer sprayed with air cleaner fluid.
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2877938
01/21/21 04:03 PM
01/21/21 04:03 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Received a set of 3” TTI exhaust this week. Looking forward to installing the system and adding electric cut outs. After it is modified to fit I will send it out to be ceramic coated to match the headers.
Pat
Re: Modern Bullitt build [Re: Keepat] #2877996
01/21/21 06:17 PM
01/21/21 06:17 PM
Medford OR
FrankenScamp Offline
Medford OR
Very cool!
Thanks for that last pic. thumbs thumbs
Re: Modern Bullitt build [Re: FrankenScamp] #2879661
01/24/21 10:34 PM
01/24/21 10:34 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Re: Modern Bullitt build [Re: Keepat] #2879738
01/25/21 08:08 AM
01/25/21 08:08 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Nice Pat!
Sounds wicked! And that's a good thing!
-larry
Re: Modern Bullitt build [Re: larry4406] #2881119
01/27/21 10:17 PM
01/27/21 10:17 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thanks Larry!
Install the windshield last night. The AMD glass fit great along with the year one gasket. Caulked the metal and glass track with Butyl rubber sealant. Will do an ultra sonic sound leak test before installing the stainless trim.
Pat
Re: Modern Bullitt build [Re: Keepat] #2881425
01/28/21 06:13 PM
01/28/21 06:13 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Beautiful car!
Re: Modern Bullitt build [Re: Keepat] #2881579
01/29/21 08:46 AM
01/29/21 08:46 AM
Norway
cudaerik Offline
cudaerik  Offline
Norway
inspiring thread to follow as I've never seen a build on this level being documented. Thanks! Are you using Butyl rubber sealant on both window and body side of the gasket?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Modern Bullitt build [Re: cudaerik] #2881815
01/29/21 06:55 PM
01/29/21 06:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Yes I use the butyl rubber sealant on both the metal side of the rubber gasket as well as the glass side of the rubber gasket. After the glass was installed but before the rubber flap was pushed in position I ran a very small bead between the rubber gasket in the glass.
Pat
Re: Modern Bullitt build [Re: Keepat] #2881837
01/29/21 08:37 PM
01/29/21 08:37 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Are you keeping it or selling it when its done?
Re: Modern Bullitt build [Re: SRT6776] #2881867
01/29/21 09:37 PM
01/29/21 09:37 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Keeper!
Re: Modern Bullitt build [Re: Keepat] #2882518
01/31/21 06:27 PM
01/31/21 06:27 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Windshield trim install with no problems other than sore palms;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2882560
01/31/21 08:15 PM
01/31/21 08:15 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Good day to be stuck in the shop with a snow storm. Started to make the custom X pipe to fit between the trans crossmember and driveshaft loop.
Pat
