Lower control arm bushing, best choice? #2801476
07/26/20 07:07 PM
07/26/20 07:07 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
We're getting some slop in our lower arm causing a constant settling of one side.
Who make the best replacement? This on a 70 RT.
Thanks, Joe
Re: Lower control arm bushing, best choice? [Re: jlatessa] #2801508
07/26/20 08:29 PM
07/26/20 08:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Proforged
Master, again and still
Re: Lower control arm bushing, best choice? [Re: DaveRS23] #2801575
07/27/20 12:42 AM
07/27/20 12:42 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
LCA bushing won't cause settling...
Re: Lower control arm bushing, best choice? [Re: Jim_Lusk] #2801604
07/27/20 07:58 AM
07/27/20 07:58 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
I saw a reply from the Charger registry that pointed to the k frame.
Reinforced our 71 K frame so maybe need some is needed on the 70.
Going to take a look in the next day or so as the car is at my son's home.
I'll reply...thanks, Joe
Re: Lower control arm bushing, best choice? [Re: jlatessa] #2801652
07/27/20 10:34 AM
07/27/20 10:34 AM
Los Osos, Ca
CKessel Online content
CKessel  Online Content
Los Osos, Ca
Maybe the tube in the K for the lower arm has come undone at the weld, cracked, nut on the shaft loosened etc. Maybe even a dead T bar.
Carl Kessel
Re: Lower control arm bushing, best choice? [Re: CKessel] #2801658
07/27/20 10:47 AM
07/27/20 10:47 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
I'm thinking the former as we replaced the T bars.
Pretty sure they were tightened after they were replaced....we'll see.
Thanks, Joe
Re: Lower control arm bushing, best choice? [Re: jlatessa] #2801909
07/27/20 09:47 PM
07/27/20 09:47 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
many junk bushings out there!!!! This was my recent experience. https://www.forabodiesonly.com/mopar/threads/lca-pin-loose-in-bushing.465142/
Based on my limited sample, seems like Proforged is the best of a bad bunch.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Lower control arm bushing, best choice? [Re: RealWing] #2801965
07/28/20 12:39 AM
07/28/20 12:39 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
More likely the problem is the rear torsion bar anchor...
Re: Lower control arm bushing, best choice? [Re: Jim_Lusk] #2802031
07/28/20 09:14 AM
07/28/20 09:14 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks, Jim, I'll eyeball that too.
Joe
