dual quad intakes? #2801262
07/26/20 09:38 AM
07/26/20 09:38 AM
bergen county NJ
fhurricane1000 Offline OP
bergen county NJ
I have 440 with 11 to 1 compression, stage 1 solid lifter cam with factory 413 dual quad set up.. I want to replace that set up with the edlebrock ch28 or offenhauser 5206. Both are dual quad intakes. Any feedback on them will be appreciated. thanks.
Re: dual quad intakes? [Re: fhurricane1000] #2801276
07/26/20 10:12 AM
07/26/20 10:12 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this is what i run around on. ch28 with two 600's. smooth power, very low maintenance.
Re: dual quad intakes? [Re: lewtot184] #2801312
07/26/20 11:40 AM
07/26/20 11:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We run a CH28 with 2 Eddy 600s street strip. Been 11.28 in a 65 Belvedere street car.
Doug
Re: dual quad intakes? [Re: fhurricane1000] #2801334
07/26/20 12:21 PM
07/26/20 12:21 PM
I would use a dual plane, not a single plane intake unless you run both carbs. using one to one linkage, not progressive tsk
Progressive will work fine on the dual plane intakes up
Re: dual quad intakes? [Re: Cab_Burge] #2801395
07/26/20 03:01 PM
07/26/20 03:01 PM
bergen county NJ
bergen county NJ
thank you
