Re: To Spray Gray or not, that is the question?
[Re: Troy]
#28018
07/02/06 05:47 PM
07/02/06 05:47 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I first cleaned and degrees the arms looking for paint and inspection marks. The only thing I came up with was orange paint on one of the adjusters and white paint on the other. I then sprayed them with Eastwood Detail Gray. I then masked off the iron end that goes into the ball joint and the adjuster finger. I shot those with a combination of Spray Gray and Satin Black paint (I lay the black down and then spray the spray gray over it. I do this to darkin up the Spray Gray)I put on the inspection marks. Mask off the "dip line" and shoot the Krylon Battery Protector. After all that I shoot it with the Matte Finish to take the gloss away.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#28020
07/02/06 05:53 PM
07/02/06 05:53 PM
Troy
West Coast, CA
The strip of metal in front of the LCA is a sample of what 1) cosmoline 2) Krylon Battery Protector and 3) Eastwood Gold out or the gold cadmium paint looks like next to each other. All of these pictures, the flash makes the paint look shinny gold and metallic. It's not. It looks real good.
[Re: Troy]
#28021
07/02/06 05:56 PM
07/02/06 05:56 PM
Troy
West Coast, CA
I like contrast. One of the reasons why I painted the iron darker that the steel part of the arm.
[Re: Troy]
#28022
07/02/06 05:58 PM
07/02/06 05:58 PM
Troy
West Coast, CA
Last one....They look much better in person but I think you all get the picture. Thanks everybody for all the help!!
[Re: 6PakBee]
#28024
07/03/06 12:40 PM
07/03/06 12:40 PM
Troy
West Coast, CA
I like powder coating!! Last a very long time, will not rust and easy clean up. The colors that they have now a days are very good with many choices. You can see a difference between powder coating and paint but there is not that much of a difference. What you can do is both powder coating and paint over the top. Powder coat the lower control arm and then go over the top of it with the Battery Protector. That will work even better than what I did.
Here is a picture of a NOS control arm....
[Re: Troy]
#28026
07/05/06 01:08 PM
07/05/06 01:08 PM
Troy,
WOW! That turned out great.
[Re: M_code_Coop]
#28029
07/06/06 01:21 AM
07/06/06 01:21 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I wonder what the shelf life is?... The way I'm going, it might take 50 years to use 6 cans.
I bought six cans ten years ago & only used two, the other four I've sealed battery terminals with for the last ten years, it still sprays fine.
[Re: autoxcuda]
#28033
07/29/09 08:44 AM
07/29/09 08:44 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Good Thread Troy. Nice work. I sort of like the idea of powdercoating then using the Battery Protector. Joe
65 Barracuda 70 Challenger
[Re: jrwoodjoe]
#28034
07/29/09 10:00 AM
07/29/09 10:00 AM
Posts: 12,425 Warren, MI
71TA
Warren, MI
Interesting reading and nice looking work. I'm not a resto guy but know that on a car to be DRIVEN that paint will be "road grit blasted" off in days. I powdercoated all my frt suspension the cast iron color and it's held up to to years of near daily driving in good weather. I even powdercaoted the T bars. Powder coating then spraying over with the Battery Protector sounds like a good plan. Man you guys and your paint dabs Just kidding. Looks spectacular.
[Re: jrwoodjoe]
#28035
07/29/09 10:07 AM
07/29/09 10:07 AM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
Joe
Here's mine, powdercoated then used Krylon batterry protector, then a matte clear on top.
