Re: Small block guys will like this: [Re: hudsonhornet7x] #2799632
07/22/20 07:21 AM
07/22/20 07:21 AM
Locomotion Offline
Locomotion  Offline
Considering the size & rpm, interesting that the headers started at only 1 3/4" & stepped to 1 7/8'. Probably to help keep the average HP up.
Just for comparison, does anyone know how much HP Glidden's Arrow was making once he got done with all of his tricks? I believe his engines were somewhere in the 320 to under 340 cu. in. range.
Re: Small block guys will like this: [Re: Locomotion] #2799678
07/22/20 09:47 AM
07/22/20 09:47 AM
pennsylvania
poboyengineering Offline
pennsylvania
The windage control tricks are cute, but how are you going to mount a trans to that with the oil drain line in the back of the block?
Looks like a purpose-built dyno hero.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Small block guys will like this: [Re: poboyengineering] #2799694
07/22/20 10:41 AM
07/22/20 10:41 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
The article seem to suggest a or range of years that the Magnum block was best. A .1 overbore on a stock Magnum block seems iffy to me. Were the cores of those blocks mentioned that much stronger and consistent with the castings? I'd also be interested is seeing that valley strengthening component.
Re: Small block guys will like this: [Re: A/MP] #2799729
07/22/20 12:03 PM
07/22/20 12:03 PM
Locomotion Offline
Locomotion  Offline
There were suppose to be some early Magnum blocks that were cast and drilled for shaft oiling. That block appears to be one of them.
Can't tell if the heads took advantage of that or the rockers were oiled through the pushrods.
Re: Small block guys will like this: [Re: Locomotion] #2799731
07/22/20 12:06 PM
07/22/20 12:06 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
1988-1992 5.9l/360 were supposed to be roller cam, but block still drilled for shaft oiling LA style heads.
I imagine the partial fill with hard block probably helps stabilize the cylinders at the .100" overbore.
