Hemi 426 Engine Cradle?
#2796091
07/13/20 10:00 AM
07/13/20 10:00 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Does anyone make an engine cradle for a 426 Hemi?
My motor is ready for the Dyno and I just realized I have no way of getting it there since the KB blocks only have the Hemi motor mounts.
I've look at Mancini, Allstar, Jegs and Summit....
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Hemi 426 Engine Cradle?
[Re: WadeMetzinger]
#2796100
07/13/20 10:13 AM
07/13/20 10:13 AM
Posts: 4,744 On the parachute mount
n20mstr
I've look at Mancini, Allstar, Jegs and Summit.... I BOUGHT A SUMMIT ONE FOR A wedge, then cut off the front mounts and welded on flat stock. Drilled holes and that's it
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2796148
07/13/20 01:02 PM
07/13/20 01:02 PM
WadeMetzinger
Tulsa, Ok
Coming up with Zero. I found this on eBay so I'll give this guy a try, he already said he can build one and ship it tomorrow with some modifications. I could modify one I have but I just don't have time at the moment. Hemi engine cradleI wished you were still making those Andy... Cab, I have a few of those but they don't attach to the motor, just sit so for around the shop they work but in the back of the truck I like them to be bolted together.
[Re: WadeMetzinger]
#2796242
07/13/20 05:03 PM
07/13/20 05:03 PM
Posts: 43,721 Bend,OR USA
Cab_Burge
I use 3.5 inch long wood screws to hold mine together I had to make several of them (6) with wheels when we moved from SO CA up here to Bend, they all held up well. I recycle our old facial boards off of our house down there, 2x8. I tied them down to in floor tie downs for the car straps in my car trailer, it was a little over 850 miles one way I did use one piece of plywood on one of them on the bottom due to running out of the 2x8 boards, all the rest had longer front and rear boards to help make sure they wouldn't tip over When I haul them in the truck I tie them down around the front and preload the back against the tail gate, 2006 ram 3500. No wheelies or sudden stop though
[Re: WadeMetzinger]
#2796244
07/13/20 05:10 PM
07/13/20 05:10 PM
Posts: 2,316 NE Ohio
DoubleD
NE Ohio
Coming up with Zero. I found this on eBay so I'll give this guy a try, he already said he can build one and ship it tomorrow with some modifications. I could modify one I have but I just don't have time at the moment. Hemi engine cradleI wished you were still making those Andy... Cab, I have a few of those but they don't attach to the motor, just sit so for around the shop they work but in the back of the truck I like them to be bolted together. I have one of those - nice well built cradle - super nice guy!
[Re: DoubleD]
#2796336
07/13/20 10:43 PM
07/13/20 10:43 PM
Posts: 7,521 Minnesota
Hemi_Joel
Minnesota
Chuck Lofgren was having them made somewhere. I'm not sure if he still is, you could give him a call. (763) 753-7573
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: WadeMetzinger]
#2796496
07/14/20 12:36 PM
07/14/20 12:36 PM
Posts: 2,136 Byron, NY
W.I.N. Racing
Byron, NY
I've made transportation cradles out of 2X6 and plywood. Something like this on a pallet
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2796533
07/14/20 01:59 PM
07/14/20 01:59 PM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
We have always just built out own out of 1x1 square tubing. Usually use the motor plate as a front mount since many have accessories attached to them and they have mounting holes already
[Re: AndyF]
#2796565
07/14/20 03:15 PM
07/14/20 03:15 PM
Cab_Burge
I made the first two wooden ones, my friend scab the steel one out of scraps he had on hand to give to me Lots of choices to get the job done
[Re: WadeMetzinger]
#2798998
07/20/20 03:51 PM
07/20/20 03:51 PM
Posts: 31,201 Oregon
AndyF
Looks good, that design is much heavier than that ones I used to build. I did use larger casters on mine. I always put 5 inch casters on my cradles so they would roll really nice.
[Re: WadeMetzinger]
#2799007
07/20/20 04:05 PM
07/20/20 04:05 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
A $10.99 harbor freight furniture dolly (1,000 lb. capacity) and some scrap wood screwed to it works for me. Have several complete engines in the shop on them so I can move them around easily. They don't roll real good, but good enough.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
