Re: 71 Charger Superbee.. no lower steering column bearing??
[Re: beepilot]
#2796979
07/15/20 01:47 PM
07/15/20 01:47 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
My 73 Challenger is that way. No lower bearing. Just the plastic piece at the bottom. I've heard that from the factory there used to be a foam seal inside the plastic piece. It kept hot air from traveling up the column and heating the interior. On my 68 Dart, there was a lower bearing but it was seized. The factory replacement was expensive so I used an ER-16 bearing instead. Lots of people are using it. https://www.amazon.com/HD-Switch-SE...&hvtargid=pla-487637004623&psc=1
[Re: gygeneral]
#2799217
07/21/20 03:23 AM
07/21/20 03:23 AM
beepilot
Excellent pictures! Thanks, that's exactly what I have. I'm having a guy on ebay make up a delrin bushing and glue it or bolt it inside that useless white plastic retainer. I know there should be a seal in that but I figure with the heat from the header close by it wouldn't last long anyway. Making OD to fit in that retainer and .100 or so bigger than the od of the shaft just in case it isn't perfectly centered to the box. should help center it for installation and reduce all that play . Feel better seeing others like it
Beautiful restoration job by the way!
[Re: beepilot]
#2799319
07/21/20 11:03 AM
07/21/20 11:03 AM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
Beautiful restoration job by the way! FWIW, I drilled a couple of holes and screws to lock mine in place.
