Re: Car won't start when hot
[Re: gygeneral]
#2800924
07/25/20 11:09 AM
07/25/20 11:09 AM
Posts: 18,422 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Final post here, its been a little over a week, and I've been able to start my car everytime using the flooded engine approach. I like these kinds these low $$ solutions for once. I simply depress the pedal halfway , hold it there and crank it and it fires right up. Thanks everyone for the suggestions. Glad it worked out. Back in the early 70's I learned that with my 69 Road Runner. Just a nature of a hot soaked beast. That was even with leaded gas. The one last thing I still will strongly suggest is a mini starter. I guarantee your crank time will be cut in half if not more.
[Re: gygeneral]
#2801105
07/25/20 06:33 PM
07/25/20 06:33 PM
NITROUSN
. The one last thing I still will strongly suggest is a mini starter. I guarantee your crank time will be cut in half if not more. [/quote] I want to keep the stock look, the whole car is done stock as its a 440-6 matching numbers car. I guess its easy to swap out if you need to. [/quote] I understand that especially if you are being judged at car shows. If it was me and just a nice driver I would run the mini and box the old one up for the day someone else buys it. I will just about bet with all the cranking that was done to it that its life is on the short side.
[Re: NITROUSN]
#2801135
07/25/20 07:52 PM
07/25/20 07:52 PM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
. The one last thing I still will strongly suggest is a mini starter. I guarantee your crank time will be cut in half if not more. I want to keep the stock look, the whole car is done stock as its a 440-6 matching numbers car. I guess its easy to swap out if you need to. [/quote] I understand that especially if you are being judged at car shows. If it was me and just a nice driver I would run the mini and box the old one up for the day someone else buys it. I will just about bet with all the cranking that was done to it that its life is on the short side. [/quote] Just looked at the Mancini Racing web pages, lots of choices for mini's, is there one that you would recomend?
[Re: Kilroy was here]
#2804003
08/01/20 11:28 PM
08/01/20 11:28 PM
Posts: 3,665 NE OHIO
kevin69bman
NE OHIO
He don't need new starter I have headers and not a problem with stock starter Its a old car with carbs and all you young guys need to know how to start them when hot or cold not like todays car when u turn key and computers decided if car can start
[Re: kevin69bman]
#2804065
08/02/20 09:10 AM
08/02/20 09:10 AM
gygeneral
Ont, Canada
He don't need new starter I have headers and not a problem with stock starter Its a old car with carbs and all you young guys need to know how to start them when hot or cold not like todays car when u turn key and computers decided if car can start Thank you for thinking I'm a young guy LOL. This is exactly my solution. Over the last month I've been experimenting and now 1. when the car is cold and has been sitting for a while, I give two to three pumps, hold the gas pedal down 1\2 way and crank 2. when its hot and only been less than 15 min after shutdown, just crank the key 3. Over 15 min , depress pedal 1\2 way , do not pump, and she fires right up So far this summer , this has worked.
[Re: kevin69bman]
#2804106
08/02/20 10:47 AM
08/02/20 10:47 AM
NITROUSN
He don't need new starter I have headers and not a problem with stock starter Its a old car with carbs and all you young guys need to know how to start them when hot or cold not like todays car when u turn key and computers decided if car can start While this is true for the most part I guarantee the cranking time will be drastically reduced with a mini starter.
