Re: 46rh Governor Questions
[Re: 46rhRebuild]
#2795161
07/10/20 02:11 PM
07/10/20 02:11 PM
Posts: 120 Florida
46rhRebuild
I apologize for the long absence, but had to focus on more immediate work for the last month.
I'm assembling the front direct clutch drum, and the frictions that I was supplied are the hi-energy waffle pattern frictions. Will this affect anything if I use these in place of the flat frictions that I see depicted in the book and videos I'm referencing?
This are the frictions that shipped with my rebuild kit, part number A22008E.
Also the gentleman in the videos says that if the clearance is tighter than .090 then binding will occur between the 2-3 shifts. The FSM states that .070-.129 is good to go. Is there any truth to this? I ask because my assembly measures at .078.
[Re: A727Tflite]
#2795242
07/10/20 06:05 PM
07/10/20 06:05 PM
Posts: 120 Florida
46rhRebuild
Yes, sir, that is exactly what I mean. I realize that I was solely focused on the front sealing ring diameter, not even thinking about the large journal that rides in the stator bushing. I'm trying to track down the smaller correct size.
Are there any major pitfalls to avoid when pressing one out and into that front drum?
[Re: 46rhRebuild]
#2795279
07/10/20 08:13 PM
07/10/20 08:13 PM
Posts: 3,089 Michigan
A727Tflite
Look closely just below that journal and you will notice a wire retainer ring. That has to come out first.
Then press the input shaft out - “up” as shown in your images.
Support the rear clutch piston support in your press as close to the diameter of the input shaft as possible, like where the thrust washer seats. I have seen guys crack the support when not doing so.
[Re: 360view]
#2795963
07/12/20 09:04 PM
07/12/20 09:04 PM
Posts: 120 Florida
46rhRebuild
If it hadn't been for Transman, I would never have been able to tackle this build with any success. I had zero knowledge of the parts differences in these transmissions, either.
I'm happy if my build can help any other people. The actual assembly isn't hard, just follow his hints! He's saved me alot of time and pulled me out of the woods everytime I've gotten stuck.
[Re: 46rhRebuild]
#2796287
07/13/20 07:54 PM
07/13/20 07:54 PM
Posts: 120 Florida
46rhRebuild
In case anyone needs to know the two different journal sizes on these input shafts, here they are.
The small shaft measures 1.159 OD on the land that rides in the stator bushing.
The large shaft measures 1.243 OD on the land that rides in the stator bushing.
[Re: 46rhRebuild]
#2807031
08/09/20 08:26 PM
08/09/20 08:26 PM
Posts: 120 Florida
46rhRebuild
Doing further research, I see that I need to install the rest of the assemblies, including the pump with no o-ring for ease of removal. Then measure total endplay with my Starret dial indicator. If I fall within specs, then I'm good to go. I've installed the intermediate of the three thrust washers first.
Endplay comes to .030 with the intermediate of the three washers installed. I'm searching through all my publications to find out if this is within spec. If anyone has specs around please post so that I can confirm.
[Re: 46rhRebuild]
#2807080
08/09/20 10:07 PM
08/09/20 10:07 PM
A727Tflite
.036 - .086” seems to be the number. I’ll check in a bit.
[Re: A727Tflite]
#2807230
08/10/20 11:48 AM
08/10/20 11:48 AM
Posts: 120 Florida
46rhRebuild
Thank you sir. Using the thinnest of the three washers will get me there, it looks like.
Here's what I did, if you don't mind checking my work.
1. Install input shaft, rear drum, then pump, aligning everything (washer and hardened race installed). I did not intall the kickdown band
2. Install gasket and hand tighten two of the pump bolts to hold it in place
3. Used a lever against the shaft (unit is upright) to move it to the extreme upward range before the transmission wants to move as a unit.
Dial read exactly .030
[Re: 46rhRebuild]
#2807460
08/10/20 09:04 PM
08/10/20 09:04 PM
A727Tflite
Since your unit is vertical already I would just install the vb and rod as an assembly. Just be aware of the position of the rod passage and focus on that during installation. It helps to have someone turn the output shaft as you install the vb/rod assy.
Don’t forget to be careful installing the vb in regards to the od plug - lightly grease that bore and the pass through plug. Start a couple vb bolts then work the linkage to make sure park works.
[Re: A727Tflite]
#2808231
08/12/20 09:06 PM
08/12/20 09:06 PM
Posts: 120 Florida
46rhRebuild
Thank you, sir. I appreciate all of the advice. I will report back once the VB is installed this weekend, and let you know how it went.
VB install will be this upcoming weekend. Still trying to find someone to swap this thing, my normal mechanic is a month and a half out.
