Re: 60 ft frustration is driving me nuts
[Re: dvw]
#2798754
07/19/20 10:22 PM
07/19/20 10:22 PM
Posts: 10,021 MN
JERICOGTX
MN
Doug, what is your driveshaft sensor issue? I have a RacePak Sportsman, and am also having issues with it.
69 GTX
68 Road Runner
[Re: dvw]
#2798821
07/20/20 07:57 AM
07/20/20 07:57 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Are you using a hall, a mag, or an MR sensor?
[Re: dvw]
#2798852
07/20/20 10:13 AM
07/20/20 10:13 AM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Well the shock having issues when compressed is NOT helping for sure. Compression is used to keep the tire planted after initial hit so entirely possible you found the issue. You will find out soon enough. As for Wilwood I was always told to use the square cut o ring, but I have found no matter which you use they will eventually be right back to hanging up again.
[Re: dvw]
#2798857
07/20/20 10:23 AM
07/20/20 10:23 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Hall effect, ZF GS 100201 Doug With that sensor it should pick up at very low speeds. I have one on one of my front wheel that reads off the wheel studs, it reads just fine just by spinning it by hand. With 22 teeth and assuming you are turning the rear tires by hand it should read no problem.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2798884
07/20/20 11:10 AM
07/20/20 11:10 AM
TRENDZ
Milwaukee WI
Been a while since Ive used logworks, but isn’t there a “speed” selection? I do agree that it should work with freq. Are you using 5v reference or 12?
[Re: TRENDZ]
#2799961
07/22/20 08:12 PM
07/22/20 08:12 PM
Posts: 9,826 MI, usa
dvw
MI, usa
First off It appears that the brakes are repaired. There were some shims supplied with a set of pads that were installed a while ago. They wouldn't fit behind the new pads , no room. They cant be more than .060" thick. I decided now that pads had a little wear to try them. The backing plate of the pad has a few 1/2"? holes. Maybe something to due with the bonding ? anyway installed the shims and you can actually spin the wheels. To the driveshaft. Yes there is a speed selection.feeding the sensor with 5 volts. My son (Dizuster here) is bringing an oscilloscope tomorrow to try and troubleshoot the driveshaft issue. New Afco big guns are on. No time to test. I'm going to go out and race it Saturday. Hopefully my guess at the shock settings is close. We'll see. Doug
[Re: nss guy]
#2801074
07/25/20 04:42 PM
07/25/20 04:42 PM
Posts: 875 Missouri
jwb123
Missouri
supposedly they are 2 different O-rings for them, square and round. I think the round are suppose to help with return. Something to check out The square ones are supposed to pull the pistons back slightly when you release the brakes. Round O-rings will leave the pistons where they are when released.
[Re: jwb123]
#2801207
07/26/20 06:48 AM
07/26/20 06:48 AM
dvw
MI, usa
Ran the car yesterday. Track prep was so so. I should've checked track temp but didnt. Air wasnt great. 90 degrees and humid.water grains over 100. That being said the car was pretty good. Took a guess at the initial shock settings and made 2 sets of adjustments. Since we were in eliminations didnt want to make to many changes. Car was very good. The new Afco rear shocks were the key. Obiviously the old rear shocks had an issue. Ran 60 ft within .01 all day. 60 ft is still slower than I'd like but I really believe part of that is the Edelbrock carbs lack of transition to the main circuit. That will be the next issue to attack once the data logger function. Car followed the weather station predictions with in less than .01 for 5 out of 6 passes. Got out of the groove in rd 4. Fell off .02. Lost by .005 Doug
