Anyone use Avgas 100 LL in place of racing fuel? #2791085
06/30/20 05:27 PM
06/30/20 05:27 PM
God's Country - Etowah, TN.
A34 Offline OP
A34  Offline OP
Hey Guys,
Has anyone ever used Avgas 100 LL in place of racing fuel? How did it work for you? Any potential dangers in using it?
Thanks!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: A34] #2791092
06/30/20 05:53 PM
06/30/20 05:53 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I personally never used it but a friend of mine did. Carb & timing adjustments. This was in a stock 440 street car that wasn’t driven all the time. Don’t want what the internals looked like. Do a google search on av gas in a car engine and make your own conclusion.
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: A34] #2791096
06/30/20 06:01 PM
06/30/20 06:01 PM
AndyF Offline
AndyF  Offline
Originally Posted by A34
Hey Guys,
Thanks!
Probably at least 10,000 people.
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: AndyF] #2791111
06/30/20 06:37 PM
06/30/20 06:37 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
I've been using it in my street driven 10.5 compression 68 GTX since I finished the restoration in 2015 and I use it in my 11.0 compression 360 Magnum 67 Dart bracket car, never had an issue, helps that I live next to a small airport. up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: RapidusMaximus] #2791127
06/30/20 06:51 PM
06/30/20 06:51 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How much is AV gas these days?? work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: A34] #2791134
06/30/20 06:58 PM
06/30/20 06:58 PM
I stop using Av Gas, not 100LL, in my race cars back in the mid 1970s after seeing the pitting the valve seats and valves it caused in high RPM motors, above 4000 RPM down
I have used some 100 LL in some other Hi Po street cars since then due to it having shelf life of 18 months, it has a noticeable distinct smell that some law enforcement officers can notice, it has a $10,000.00 Federal fine on using it on the street due to the lead content, if they want to write you up for that work scope twocents
I owned and flew a small airplane for a little over 15 yrs, spent around 900 hours in flying it with using 100 LL only fuel in it.
Before leaded additives where outlaw for street gasoline there was three different blends of Aviation gasoline in the 1970s, 85/100, 100/115 and 115/145 which later became 115/130 octane. I use the 100/115 in my race cars back then realcrazy
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: Cab_Burge] #2791173
06/30/20 07:39 PM
06/30/20 07:39 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Long, long ago- like 40 years ago - some of us SoCal guys ran either 100 or 110 IIRC AvGas..
We had an "in" at the Van Nuys Airport.
Those were 12.0-12.8:1 street racing deals.
Don't recall much about any long-term effects.
Probably a different blend nowadays, anyway.
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: hemi-itis] #2791186
06/30/20 08:06 PM
06/30/20 08:06 PM
AndyF Offline
AndyF  Offline
http://www.100ll.com/
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: AndyF] #2791233
06/30/20 09:24 PM
06/30/20 09:24 PM
AndyF Offline
AndyF  Offline
Previous thread on avgas. The topic comes up a couple of times a year.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2560934/1.html
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: AndyF] #2791242
06/30/20 09:34 PM
06/30/20 09:34 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
I've not used it in years, and over here, it's just easier to buy some of the more basic race fuels.
I don't really recall there being any real difference in power, compared to the 100 octane race fuel I used instead of the AVgas. I recall the AVgas likeing more ignition timing.
Alan Jones
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: AndyF] #2791370
07/01/20 08:40 AM
07/01/20 08:40 AM
A34 Offline OP
A34  Offline OP
Thanks, I did a search first and didn't see anything. up
DEO VINDICE
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: A34] #2791379
07/01/20 09:00 AM
07/01/20 09:00 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I know a few guys that run it and it seems to work okay. My sister runs it in her car and hasn't had any issues. I tried it 2 years ago and made a whooping 2 passes with it. My engine is 11:1 and I was doing a mixture of pump/race gas before so I tried it. Had to readjust the floats. I drained out the tank, filled with AV gas. On the 1st pass the car stumbled. On the 2nd pass the car kept wanting to shut off. I was able to get the car back to the pits and realized the fuel pump was acting up until it finally wouldn't run at all. I don't think the AV gas had anything to do with it since the Holley Black pump was about 12 years old, but I ended up draining the tank, going back to my pump/race gas combo and putting a new fuel pump on the car. Used the rest of the AV gas in the lawn mower. At that time AV gas was like $2.50 a gal.
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: DusterKid] #2791380
07/01/20 09:09 AM
07/01/20 09:09 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I started having Sunoco 100 unleaded delivered in the 54 gallon drum. I switched my cars over to F.I., so I can't use leaded anymore. Seems the Sunoco 100 works well in my 10.8:1 440 stroker, 87 Buick GN and my 11:1 stroker small block.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: ChrgrCuda] #2791382
07/01/20 09:37 AM
07/01/20 09:37 AM
IL
Dart451 Offline
Dart451  Offline
IL
Know many people that have used it for years never a problem. Some big blocks with high compression some boosted LS engines
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: A34] #2791385
07/01/20 09:41 AM
07/01/20 09:41 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I cannot give you the details or the science behind it but I have heard folks say that the Avgas is blended for high altitude use and that makes it less than optimum for race cars.
I had a friend that was an engineer that said Avgas burned too "dry". I don't really know what he meant.
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: 340Cuda] #2791508
07/01/20 01:34 PM
07/01/20 01:34 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
well be prepared to clean your plugs and dont idle too long. Tops of pistons will get lead deposits but it runs good. 100 Low lead is not really low lead. I would blend it with 91...and I clean a lot of spark plugs at work because we have 50 airplanes and about half run low lead...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: 340Cuda] #2791747
07/02/20 12:15 AM
07/02/20 12:15 AM
Originally Posted by 340Cuda
I I have heard folks say that the Avgas is blended for high altitude use and that makes it less than optimum for race cars.
two things about todays 100 LL, it is a lot thinner, less specific gravity, than todays pump gas or todays race gas. Maybe he was referring to this shruggy As far as altitude and the design of Av Gas back in the day when commercial pressurized airliners ran Av gas they did tend to fly a little higher on the altitude than your normal non turbo charged or super charge piston engine airplanes fly normally for several reasons.
Most piston driven non pressurized airplanes used today fly at or under 12,500 ft. above sea level for several reasons, one of them being the pilot is required to use oxygen above 12,500 if they are above that altitude for more than 20 minutes.
I flew a friend and his grown 30 yr old Son to Denver and back from SO CA around 20 yrs ago, I had a five place oxygen system in the airplane with new canula for breathing at or above 12,500 ft. I had to go above 12,500 ft. going and coming back and they didn't want to use them, they both went to sleep and where groggy with a head ache on the return trip. I decided to fly direct from Denver to the Grand Canyon airport on the return trip to save time and fuel as we where able to depart the small airport in south Denver before 9:30 AM. I flew at 16,500 Ft for around 1 hour before descending down to 8,500 near Gallup N.M. so they wouldn't get oxygen starvation and suffer for the rest of the day. That didn't work as the damage had already been done realcrazy
I had to lean the mixture out mechanically from the cockpit with the leaning mixture knob anytime I flew 3,000 above sea level to avoid fouling the spark plugs wrench I accidently foul one spark plug on my second flight after buying he airplane, only once work That is not a good feeling when you loose the use of one cylinder on a six cylinder engine and your 3000 + Ft above the ground tsk
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: 340Cuda] #2791958
07/02/20 04:23 PM
07/02/20 04:23 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I always like hearing this, its for high altitude. Pretty sure all airplanes take off from the ground and also pretty sure taking off takes more power than actually flying. I use it, and love it. 12 to 1. The car doesnt get driven much, so when the fuel evaporates, it doesnt leave any "goo" in the carbs. You have to jet up a little, not much, but some to make it run right. Carry on. It was 4.50 a gallon at the airport near me. LOL
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: Dodgeguy101] #2792045
07/02/20 09:17 PM
07/02/20 09:17 PM
jersey
Spaceman Spiff Offline
jersey
then why does a place like denver, have a different formulation of fuel....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Anyone use Avgas 100 LL in place of racing fuel? [Re: Spaceman Spiff] #2792100
07/02/20 10:53 PM
07/02/20 10:53 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I use it in everything. My 12:1 Sport Bike, ATV's, Motocross Bike, 9:1 Magnum engines, 11:1 Gen 3, and all of the old cars. My fuel mileage is always better, they start quicker, and responsiveness at the pedal is noticible.
I blend it to pump regular because I always question how long premium sits around at gas stations. "Pump premium" is likely stale and dropped a few points from what is claimed on the sticker.
I'd rather the Haters keep hating on LL so there is more for Me. up
Mo' Farts
Moderated by "tbagger".
