Milling heads for compression #2790702
06/29/20 04:12 PM
06/29/20 04:12 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
How much does every .010 decrease chamber size on the closed chamber heads? Trying to get BGE head to eagle chamber size.
Re: Milling heads for compression [Re: HotRodDave] #2790803
06/29/20 09:24 PM
06/29/20 09:24 PM
GA
roadrunninMark Offline
GA
Here is a good compression calculator.... https://diamondracing.net/p-10-compression-calculator.html
Re: Milling heads for compression [Re: roadrunninMark] #2790908
06/30/20 08:34 AM
06/30/20 08:34 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
He is not looking for a calculator, but the information for how many thousandths need to be removed to reduce chamber volume by 1cc
Re: Milling heads for compression [Re: HotRodDave] #2792536
07/04/20 07:45 AM
07/04/20 07:45 AM
Australia
aus370 Offline
aus370  Offline
Australia
.0065" off for a 1cc chamber reduction was the figure i found for closed chambers . In reality my Apaches required .020 off for a 2.1 cc reduction , But ! that was after some chamber work and a valve job.
Re: Milling heads for compression [Re: aus370] #2792622
07/04/20 12:59 PM
07/04/20 12:59 PM
Kalispell Mt.
Kalispell Mt.
Thanks, thats what I needed to know. So double check my math, I need to remove about .030 to keep them roughly the same size?
Early 5.7 85 CC
Eagle 5.7 67 CC
SRT 6.1 73 CC
6.2 and 6.4 73 CC
Is it OK to take off .030 on my BGE heads?
Re: Milling heads for compression [Re: HotRodDave] #2795237
07/10/20 05:48 PM
07/10/20 05:48 PM
Australia
aus370 Offline
aus370  Offline
Australia
Assuming your basing it on .0065 for 1cc , then my math says .030" of would be a 4.615cc reduction . i think an experienced machinist will get what you want .
Remember to deepen the rocker shaft oil feed slot by the same amount removed from head.
