Re: Getting beat down by a lawn mower
[Re: moparx]
#2790633
06/29/20 12:14 PM
06/29/20 12:14 PM
Posts: 8,414 Highland, MI.
Sunroofcuda
Highland, MI.
Well, I just ordered a new $17.88 carb from Amazon for my Troy Bilt with Briggs 550EX "no start" engine. We'll see what happens! Also, I switched over to ethanol-free fuel after the last trip to the small engine guy & that did not fix my yearly spring no-start problem, AND I do use Sea Foam every fall. (I hardly ever use the mower)
This thing has been nothing but a POS ever since it was new. I maybe have 6 hours on it.
[Re: Sunroofcuda]
#2790637
06/29/20 12:24 PM
06/29/20 12:24 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This thing has been nothing but a POS ever since it was new. I maybe have 6 hours on it. Seafoam is for use during the summer season not winter prep. Stabile fuel treatment is for winter storage.
[Re: fastmark]
#2790699
06/29/20 04:04 PM
06/29/20 04:04 PM
Posts: 2,370 Wheatfield, NY
Cuda340
Wheatfield, NY
Sometimes the vent in the gas cap plugs up and it starves for fuel. Take the cap off and see if it runs longer than two minutes. This and the only thing you really changed is the fuel filter. It may be staving the bowl. Also clean the carb again with some compressed air and carb cleaner. Did you change any of the air bleed screw settings?
[Re: pittsburghracer]
#2790713
06/29/20 04:40 PM
06/29/20 04:40 PM
Posts: 6,356 nowhere
Sniper
nowhere
Why would you store a lawnmower for the winter with gas in it?
[Re: Sniper]
#2790715
06/29/20 04:48 PM
06/29/20 04:48 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why would you store a lawnmower for the winter with gas in it? Because this system works well for me and always has.
[Re: mopars4ever]
#2790752
06/29/20 06:39 PM
06/29/20 06:39 PM
Posts: 4,924 new berlin wisconsin
Mr T2U
i have a probably a 20yo craftsman lt100 rider. bought it used 11 years ago so i really don't know how old it really is. 17hp 42" cut. i have never changed the plugs or the air filter. only the belts, blades, and battery. i just changed the oil last year for the first time. i don't winterize it, just park it for the winter and remove the battery. throw the battery in in spring and it's runs after a couple of turns of the motor.
perception is 90% of reality
[Re: poorboy]
#2790817
06/29/20 09:43 PM
06/29/20 09:43 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought my Sears craftsman 42 inch cut tractor in 1999. She’s getting old.
[Re: buildanother]
#2791616
07/01/20 06:26 PM
07/01/20 06:26 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The plugged air filter would sure be an easy fix. I fixed mine a couple years ago with a few holes punched through it until I could buy one at store. I think that Feets guy would have checked that by now.... You mean like the new one I installed when I did the rest of the work?
[Re: A12]
#2791619
07/01/20 06:33 PM
07/01/20 06:33 PM
feets
Senior Management
Senior Management
Irving, TX
feets I don't know if your carb has a black plastic cap, cover or screw on the left top side of the carb (white arrows area) that will have that vent passage when removed? That's what causes symptoms as you describe when it gets even a little blocked. If it does cleaning it with some carb cleaner and air pressure and best with an ultrasonic parts cleaner should fix it............ ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) Sure sounds like a float bowl venting issue to me as the float bowl holds about 1-2 minutes of running time fuel.......or less. That sounds like it might be the issue. Thanks!
[Re: Sunroofcuda]
#2796003
07/12/20 11:07 PM
07/12/20 11:07 PM
Sunroofcuda
Highland, MI.
This thing has been nothing but a POS ever since it was new. I maybe have 6 hours on it. Well, I just had time to install the new Chinee carb & first pull it started right up, but it runs at a low-ish RPM & it surges. There is some kind of solenoid & I'ma wondering if this is the cause of the surge? You can watch the linkage moving which causes the surge. There is no throttle control with this mower - it's either full on or off. This thing is SUCH a piece of crap!
