Re: 70 cuda and trans cooler lines
[Re: 8urvette]
#2806655
08/08/20 06:20 PM
08/08/20 06:20 PM
Posts: 4,701 On the parachute mount
n20mstr
How do you install the rear quarter glass in a tubbed car. I have it in the spot where i want it to live, obviously due to tub size they will never move, but what do you do to mount them solid? . Prop the window in there , hold it in with some duct or 2" masking tape. Look at the bottom of the window, should have some hole to bolt it to the regulator. Get some flat 1" or 1 1/2" alum from a hardware or Home Depot. Bolt it to the window and somewhere to hol the window in place. Hope that helps
....BAD A$$ STREET CAR.....
