Re: Help selecting home security camera system
[Re: Ramrod39]
#2787530
06/20/20 07:19 PM
06/20/20 07:19 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I got a read deal on Ring stuff, (w/o the deal I never would have paid what they cost full price) have a doorbell cam and 2 floodlight cams. They work great and the online cloud storage of video costs $10/mon or $100/yr but it works reliably.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2787698
06/21/20 10:54 AM
06/21/20 10:54 AM
Andrewh
budget matters, how tech savy are you matters, as 5th ave mentioned, how wireless is wireless to you. There are battery operated camera's, but it gets expensive even with rechargeable, as they don't last that long. There are also people that wire up battery packs to power non-battery operated camera's in hard to get at area's of the home or away from power. using inverters and POE type camera's.
also some expectations should be set depending on budget and what you plan on doing with the camera's as well.
night vs day, distance, PVR record time, clarity, notifications or remote viewing. All of these change the price point, some a little, some dramatically.
Piecing together a system can be done, but cost will be a factor. While it is true you are allowing flexibility of cameras, the capture portion depending on the camera can be expensive. There are "free" softwares out there that let you use generic IP camera's as well. but then they limit the ability to use them till you pay for that feature.
You should also be careful about "cloud" based storage or company storage like Ring. If the internet goes out you don't get a recording of what happened. like the old days where they cut your phone line and no alarm goes out, cutting your cable / internet means ring doesn't record what happened when they come to your front door. a few others are like that wyze is like that, but they do offer the ability to put in a memory card in their camera's so at least you have local recording.
Reolink is the one I currently use, but that was more budget minded. I have added on to the original system a few times, but may have to step up due to clarity issues, as well as speed to view on their apps.
all that was to say, what are you trying to use it for, and what kind of budget do you have in mind. how easy is it to run power vs actual cable connections? As I have places I can run power easy, but to get ethernet back to a central place would be impossible.
[Re: 65fury]
#2787756
06/21/20 01:20 PM
06/21/20 01:20 PM
Posts: 4,153 Canada -- Posts: 4034 -Registe...
5thAve
My wife did the research and she purchased the Blink system. She knew if it was a complicated install that it wouldn’t ever get done. I think it took me 20 minutes to install three cameras. Truly wireless, the ONLY caveat to the system is you need to keep the stepladder handy with a bulk pack of lithium AAs as you’ll be changing the batteries every now and then. My kids play in the yard and front porch all the time and trigger the hell out of the cameras and even with that wasted energy the battery replacement is still a small price to pay IMO for the convenience of the system. This is geared for the people with good WiFi and smartphones. If you have a flip phone you’re missing out on most of the system’s convenience. Sensitivity and quality are all very adjustable and the motion detection is so advanced, you can gray out certain areas of the picture and it will ignore motion there. This is very handy if you want good sensitivity on the driveway without false triggers every time a car goes by or neighbor walks down the sidewalk. They’re still tweaking the effectiveness of that feature, it’s pretty new. Everything is adjusted and viewed from your smartphone I will try to upload a couple screenshots of the adjustment page. How long do the batteries last? How good quality is the videos? Does it work without internet?
[Re: 5thAve]
#2787786
06/21/20 02:30 PM
06/21/20 02:30 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
My wife did the research and she purchased the Blink system. She knew if it was a complicated install that it wouldn’t ever get done. I think it took me 20 minutes to install three cameras. Truly wireless, the ONLY caveat to the system is you need to keep the stepladder handy with a bulk pack of lithium AAs as you’ll be changing the batteries every now and then. My kids play in the yard and front porch all the time and trigger the hell out of the cameras and even with that wasted energy the battery replacement is still a small price to pay IMO for the convenience of the system. This is geared for the people with good WiFi and smartphones. If you have a flip phone you’re missing out on most of the system’s convenience. Sensitivity and quality are all very adjustable and the motion detection is so advanced, you can gray out certain areas of the picture and it will ignore motion there. This is very handy if you want good sensitivity on the driveway without false triggers every time a car goes by or neighbor walks down the sidewalk. They’re still tweaking the effectiveness of that feature, it’s pretty new. Everything is adjusted and viewed from your smartphone I will try to upload a couple screenshots of the adjustment page. How long do the batteries last? How good quality is the videos? Does it work without internet? How quick is the reaction to motion sensor? Instant recording, or is there a delay?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 65fury]
#2788308
06/22/20 11:59 PM
06/22/20 11:59 PM
5thAve
Batteries could last a year in a house with adults or 6-8 weeks if you’ve got kids playing in the backyard and forget to disable the motion detection. Quality is good, does not work without internet. You can toggle notifications from the app. We had a high school kid drive through our backyard one afternoon and we got a notification instantly, within 30 mins we not only figured out who it was, he was notified we had him on camera (he didn’t tear up the yard he was playing cat and mouse with other kids/cars) and he apologized. Thanks, Good to know on bttery life. I'm looking for something that's not cloud based. At the moment i use trail cams and can at least check them from time to time to see what's going on and have picture record of who comes and goes.
[Re: MI_Custumz]
#3141270
04/28/23 07:40 PM
04/28/23 07:40 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I just went through this. Got talked out of wireless and ended up with 5 cameras from back street surveillance.
[Re: markz528]
#3141303
04/29/23 12:21 AM
04/29/23 12:21 AM
Posts: 10,220 Someplace you aren't
SomeCarGuy
Ring with the solar panel has been working well for 2 years so far. I have another one that is a hardwired floodlight, and a couple that run off batteries. Those last a few months at a time, more in the warm, less in the winter of course. I keep a spare and rotate them and it’s no big deal. Have the door bell too.
I want my fair share
[Re: SomeCarGuy]
#3141459
04/30/23 07:17 AM
04/30/23 07:17 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I just recently bought a couple of Wyze Pan Cams. They can pan and tilt and they were $60 with the outdoor wiring kit. They work very well with some exceptions. They do some weird stuff, the backyard cam occasionally just turns around and faces the house for no reason, and my front yard cam stop detecting motion. They track motion which is nice, when someone gets out of their car in the driveway it follows them all the way to the door and back. They have a great picture and good sound, since you can move them around they can take the place of 2 cameras in some cases. They have had 2 updates in the few weeks I have had them so they seem to be working on them.
You get more features if you subscribe to the cloud service which is $20 per camera.
68 Barracuda Formula S 340
