Re: Help finding power window electrical terminals
[Re: DaveRS23]
#2786250
06/17/20 09:06 AM
06/17/20 09:06 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Phenolic plastic doesn't melt. Is like the Thermoquad body. It cracks being hitted but doesn't melt with heat. Be confident with that. A 35-40 watts soldering gun will make the job. doesn't need more
as I mentioned, Is an option if you are out of tired of any other option. And a still clean option
[Re: NachoRT74]
#2786254
06/17/20 09:12 AM
06/17/20 09:12 AM
NachoRT74
Valencia, España
FYI, 60s,70s,80s, Mercedes ignition switches uses same kind of conections ( I know it because I have a W116 Mercedes I had to fix the ign switch ), just that I don't know the exact pin diameters. It should be metric of course. The terminals play loose into the female platic plug and just fit tight once female plug is assembled, just like the Mopar power window ones EDITING and clusters too, several switches.... that could be another source
[Re: TJP]
#2786594
06/17/20 08:48 PM
06/17/20 08:48 PM
Posts: 12,256 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I may have something that will work, I'll check tomorrow and post back Thank you for the effort but I think I have it covered now.
Master, again and still
[Re: DaveRS23]
#2786657
06/18/20 02:43 AM
06/18/20 02:43 AM
NachoRT74
Valencia, España
Woah! Those terminals are available around, not cheap, but new. Use to be listed for Buick ( GM products in general ). Didn't posted because I thought weren't to fit into the plastic housing. https://www.ebay.com/itm/Chevy-Powe...3?hash=item2cdbb04b4f:g:HvoAAOSwS~Fbo7g2Sure will be available around from cheaper sources other than resto shops ( i.e. Electrical suppliers ) but dunno how they are called.
[Re: NachoRT74]
#2786660
06/18/20 03:13 AM
06/18/20 03:13 AM
NachoRT74
Valencia, España
[Re: NachoRT74]
#2786690
06/18/20 08:44 AM
06/18/20 08:44 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You make a good point about the terminals fitting into the plastic cover. Which is why finding the complete assemblies on that old Chrysler is so cool. It had it all. It was interesting to compare the '72 Chrysler wiring connections to the connections on my '70. The connections on my '70 are pretty lame and fragile. The '72 seems to have addressed most of what I felt were problems with them. Mopar clearly needed better engineers on their early power window project. Situations like that is why my father and many other people of his generation would not own a car with power windows. And thank you for the world wide research. Some of those may have been viable. The biggest issue that I saw was that none of them gave a grip range for my posts.
[Re: DaveRS23]
#2786718
06/18/20 09:51 AM
06/18/20 09:51 AM
NachoRT74
Valencia, España
I haven't checked the specs on the pin grip being offered by the Mouser website to know if matches the size
[Re: Powerflow]
#2786999
06/19/20 03:25 AM
06/19/20 03:25 AM
NachoRT74
Valencia, España
I already had searched at repairconnector and no, they don’t have those.
( aside some other members already posted links from them on earliers posts )
[Re: DaveRS23]
#2792471
07/03/20 10:39 PM
07/03/20 10:39 PM
Posts: 1,177 People's Republic of Kali
70runner
You make a good point about the terminals fitting into the plastic cover. Which is why finding the complete assemblies on that old Chrysler is so cool. It had it all. It was interesting to compare the '72 Chrysler wiring connections to the connections on my '70. The connections on my '70 are pretty lame and fragile. The '72 seems to have addressed most of what I felt were problems with them. Mopar clearly needed better engineers on their early power window project. Situations like that is why my father and many other people of his generation would not own a car with power windows. And thank you for the world wide research. Some of those may have been viable. The biggest issue that I saw was that none of them gave a grip range for my posts. Noticed the same thing when I was repairing PW stuff, the later C body connections seemed more secure...so I used them for harness repairs whenever possible. Glad you were able to find a donor.
