4 speed pedal set, now auto?? #2783759
06/10/20 03:48 PM
06/10/20 03:48 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Converted our 71 RR to auto.
We now have a perfectly restored 4 speed pedal set to contend with.
Should we just let the clutch pedal lay on the floor or can we take the clutch
mechanism out and still have workable set-up?
Any body do this?
Thanks Joe
Re: 4 speed pedal set, now auto?? [Re: jlatessa] #2783765
06/10/20 04:01 PM
06/10/20 04:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Can you hide the pedal under the carpet? If you can I'd leave it just in case.
Re: 4 speed pedal set, now auto?? [Re: stumpy] #2783889
06/10/20 09:13 PM
06/10/20 09:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Just pull the pivot pin and remove the clutch pedal. You could also install an automatic pedal at the same time. Save whats left in a box should you ever need to change back.
Re: 4 speed pedal set, now auto?? [Re: jlatessa] #2783978
06/11/20 08:06 AM
06/11/20 08:06 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
That pedal and spring should work for my conversion to 4spd. PM me if you are interested in selling it.
Re: 4 speed pedal set, now auto?? [Re: gzig5] #2784047
06/11/20 11:22 AM
06/11/20 11:22 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
I'll need a 727 set up to make that happen, have one?
What years interchange ??
Joe
Re: 4 speed pedal set, now auto?? [Re: jlatessa] #2784309
06/11/20 08:56 PM
06/11/20 08:56 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
My thought was that the 71-74 B-body and 70-74 E-Body interchange. At least the 4spd pedals do. The 73-74 have slightly different brake pedal shape than the earlier ones but they bolt in and work in earlier cars and vice-versa. I have a 73 Cuda with an automatic and the dash and everything happen to be out of it at the moment. The main frame should be the same or compatible. I think it should bolt in for you but we'd need to do a little homework. PM me if you want and we can figure it out. There is a 73 charger in the shop that is a four speed and I can ask.
Re: 4 speed pedal set, now auto?? [Re: jlatessa] #2784310
06/11/20 08:58 PM
06/11/20 08:58 PM
AndyF Offline
AndyF  Offline
I sold the manual trans pedal box from my last car when I converted to auto. A manual pedal box brings good money these days. Look on the Brewer website, I think they have prices listed for them.
Re: 4 speed pedal set, now auto?? [Re: AndyF] #2784311
06/11/20 09:00 PM
06/11/20 09:00 PM
A727Tflite Offline
A727Tflite  Offline
The clutch pedal has been hiding under the carpet on my A12 car since 1971. Someday I’ll put the manual back in it.
Re: 4 speed pedal set, now auto?? [Re: jlatessa] #2784468
06/12/20 07:56 AM
06/12/20 07:56 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
When i did an auto to 4spd swap in my aussie a body charger, I found that there was a significant difference on where the brake rod was mounted to the pedal arm
You ever notice brakes seem easier/touchier in an auto? this is because the lever point is changed and the amount of effort required to push the pedal changes, I ended up drilling an extra hole in the manual pedal to make the brakes more responsive to a quick tap, with the frankenstein of brake parts from 3 different models, it turned into the best brake system ive ever had in an old car, made it very nimble in traffic
It was 25 odd years ago now so i cant tell you which way it goes, but a quick look at both arms together will show the difference and where to drill if you want to try it
Re: 4 speed pedal set, now auto?? [Re: Alchemi] #2784795
06/12/20 10:29 PM
06/12/20 10:29 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks folks, I'll do more digging and look at the
assembly mocked up to see what options it gives me.
I don't want to get into re-inventing the wheel here, if i can keep the clutch pedal out of the way easily, I may go that way.
We'll see, I keep you up to date when that happens.
Joe
