Tach acting erratic. 69 dodge #2765544
04/18/20 04:07 PM
04/18/20 04:07 PM
Detroit
Kidsixpack Offline OP
Detroit
I have a monster tach in my 69 bee. The original tach was 900rpm off so I updated it some time ago. The car starts and runs fine. After warming up the tach is jumping around. I haven’t driven it during the erratic behavior yet.
Do you guys think it may be the tach or some sort of electrical gremlin effecting the tach. Where would you look first?
Thanks!
KID
Re: Tach acting erratic. 69 dodge [Re: Kidsixpack] #2765549
04/18/20 04:11 PM
04/18/20 04:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you changed anything in the ignition since installing the tach?
Re: Tach acting erratic. 69 dodge [Re: stumpy] #2765563
04/18/20 04:52 PM
04/18/20 04:52 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If the tach wire is too close to a spark plug wire it will do what you described. Been there done that....
Re: Tach acting erratic. 69 dodge [Re: Neil] #2765623
04/18/20 07:31 PM
04/18/20 07:31 PM
Detroit
Detroit
Nothing new in the ignition system. The tach is wired to the hidden MSD. It’s all been on the car for around ten years.
KID
Re: Tach acting erratic. 69 dodge [Re: Kidsixpack] #2765923
04/19/20 12:55 PM
04/19/20 12:55 PM
moparx Offline
moparx  Offline
MSD box overheating because it's hidden ? loose/corroded tach connection on box ?
beer
Re: Tach acting erratic. 69 dodge [Re: moparx] #2765961
04/19/20 01:57 PM
04/19/20 01:57 PM
Detroit
Detroit
beer
I will check this.
KID
Re: Tach acting erratic. 69 dodge [Re: Kidsixpack] #2781484
06/04/20 07:19 PM
06/04/20 07:19 PM
Detroit
Detroit
Still dealing with this issue. Runs well until it gets up to operating temp. Turns out that my cap and rotor both burned up. Swapped them out. still jumping tach. Swapped out the coil. Still jumping tach.
Replaced the distributor, cap and rotor again. Still not fixed. I've suspected the MSD from the very beginning. Swapped in my original Duel Point. Haven't gotten the car started yet so I don't know if removing the MSD from the equation is the fix or not. I'm going to tinker with this for now, but I did pick up another MSD to swap in.
KID
Re: Tach acting erratic. 69 dodge [Re: moparx] #2781500
06/04/20 07:46 PM
06/04/20 07:46 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
beer
Mine was a loose/high resistance connector right on the negative side of the coil
Obviously looking at it , you sure in the hell couldnt tell when it had full insulation/rubber over terminal end
Didn’t figure it out until I took an ohm meter on the wire itself and had the wife wiggle and bend and move the wire around
And then when I finally took/peeled the insulation off you could see the dark area
Was a bad connection I would assume since new , as it progressively got worse over the years
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Tach acting erratic. 69 dodge [Re: bee1971] #2781695
06/05/20 12:28 PM
06/05/20 12:28 PM
moparx Offline
moparx  Offline
over the years, connections like that have driven me nutz !
glad you found that. up
hopefully, the OP can find his problem and report back.
beer
Re: Tach acting erratic. 69 dodge [Re: Kidsixpack] #2781712
06/05/20 12:43 PM
06/05/20 12:43 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
KID
Including the Monster Tach?
Kevin
Re: Tach acting erratic. 69 dodge [Re: Twostick] #2781751
06/05/20 02:02 PM
06/05/20 02:02 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Is it possible you're not getting enough juice?
I had this issue a number of years ago.
I had a stock alternator. The issue just kind of crept up on me. Add the msd, add an electric fuel pump, add some more gauges and then, the alternator just could not keep up. Most of the time, mine would do what you're describing. It would not happen until the car was warmed up. The gauge would show that the system was charging good but, the battery was getting low.
Other than the tach, the car never did anything stupid and ran fine. After I would drive it for the day, back on the trickle charger it went; rinse and repeat and the same thing happened for years. The tach was old so; I thought it was just a little finicky.
I can't even remember what finally clued me in to the issue but, I installed a new, higher rated alternator and the issue never happened again.
Maybe check the volts on the battery after driving it? It doesn't take much for electronics to act funny.
Re: Tach acting erratic. 69 dodge [Re: Twostick] #2787269
06/19/20 10:11 PM
06/19/20 10:11 PM
Detroit
Detroit
KID
Kevin
Yes the tach has been on the car at least as long as the MSD. Planning to try to work on it this weekend, Will update this post.
KID
Re: Tach acting erratic. 69 dodge [Re: Kidsixpack] #2787270
06/19/20 10:12 PM
06/19/20 10:12 PM
Detroit
Detroit
I did find a couple of questionable connections. Repaired them. No change so far. I did this when I replace the Distributor.
KID
Re: Tach acting erratic. 69 dodge [Re: Kidsixpack] #2787333
06/20/20 09:26 AM
06/20/20 09:26 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Your tach could be bad. I had an Auto Meter tach go bad years back, the 340 developed a mis and a jumping tach needle that I couldn't track down to any certain cylinder. I replaced all the electrical components in the ignition system, no fix. I disconnected the tach wire and the mis went away. Hooked it back up and the mis came back. It was the tach all along.
Re: Tach acting erratic. 69 dodge [Re: Kidsixpack] #2787337
06/20/20 09:35 AM
06/20/20 09:35 AM
Indiana
68_661charger Offline
Indiana
Idk about MSD part but my tach has a good ground on the engine instead of the dash frame. Maybe try switching it if its not there already.
