70-71 Cuda fuel filler neck.. all the same #2781100
06/03/20 03:07 PM
06/03/20 03:07 PM
Sweden
71redcuda Offline OP
Sweden
Hello all!
Have a question.. there is 2 styles of original gas caps for Cudas in 70 and 71.. vacuum and vented.
But is all 70-71 cuda fuel filler necks the same?
Nicklas
Re: 70-71 Cuda fuel filler neck.. all the same [Re: 71redcuda] #2781131
06/03/20 04:55 PM
06/03/20 04:55 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Early model and late model necks starting on the 70..even the 70 uses several caps
Re: 70-71 Cuda fuel filler neck.. all the same [Re: AARCONV] #2781140
06/03/20 05:20 PM
06/03/20 05:20 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
only the caps vary,
the filler neck "tube" was the same for 1970 and listed as thru 6-1971.
the caps had different versions for both years
here are 3 different versions of parts books for reference
