68 440 Distibutor #2780614
06/02/20 10:16 AM
06/02/20 10:16 AM
Columbus, Ohio
Chally426 Offline OP
Columbus, Ohio
So, The distributor out of my 68 GTX 440, appears to have been painted black... The question is, is this factory or not? Everything, including the vacuum advance is painted black
Re: 68 440 Distibutor [Re: Chally426] #2780627
06/02/20 10:41 AM
06/02/20 10:41 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Prestolite dual point were black, but I can't remember a black vacuum pod.
Joe
Re: 68 440 Distibutor [Re: jlatessa] #2780635
06/02/20 11:02 AM
06/02/20 11:02 AM
Columbus, Ohio
Columbus, Ohio
I should have mentioned, this is a single point...
Re: 68 440 Distibutor [Re: Chally426] #2780825
06/02/20 05:40 PM
06/02/20 05:40 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
single point were bare aluminum with a clear zinc plated vacuum advance can
Re: 68 440 Distibutor [Re: gtx6970] #2780907
06/02/20 09:41 PM
06/02/20 09:41 PM
VA
dragon slayer Offline
VA
Chrysler did have Single Point Cast Iron distributors. IBP but also their own type, probably on a C body though.
If aluminum some one painted it. If Cast Iron type, should be black. But as stated vacuum advance should not be painted.
Re: 68 440 Distibutor [Re: dragon slayer] #2780963
06/03/20 07:13 AM
06/03/20 07:13 AM
It's a dry heat
It's a dry heat
Not in 1968 that Im aware of.
Single point Prestolite dists were early 60s that Im aware of
Re: 68 440 Distibutor [Re: gtx6970] #2780970
06/03/20 08:34 AM
06/03/20 08:34 AM
VA
VA
I was not assuming it was his original distributor; just pointing out the variations in that time frame. It could have anything in it.
