Tire size recommendation #2780345
06/01/20 02:07 PM
06/01/20 02:07 PM
North Carolina
469runner Offline OP
North Carolina
Will a 245-60-15 tire fit on the front of a 1970 Plymouth 'Cuda? I have been using a 235-60-15 with no problems. Just want to get a little more meat in the wheelwells.
Re: Tire size recommendation [Re: 469runner] #2780348
06/01/20 02:10 PM
06/01/20 02:10 PM
Kirkland, Washington
Pacnorthcuda Offline
It’s difficult. I tried and it rubbed a lot, went back to 235’s. If you are willing to live with a front end AT LEAST at stock height, maybe a bit more, you can probably do OK. They will still rub a bit a full lock of course.
I run my front about 1-1.5” below stock and 245’s a no go for me. 70 Cuda, 440.
Re: Tire size recommendation [Re: 469runner] #2780349
06/01/20 02:13 PM
06/01/20 02:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that is barelly 3/8" wider and a bit more than 7/16" total height than your actuall tire. That would be easy to picture on your mind looking at your car now
