Page 2 of 3 1 2 3
Re: results of added compression to 511 [Re: CSK] #2780166
05/31/20 08:09 PM
05/31/20 08:09 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Race weight is 3380. I'm gonna have to check Wallace calculators for hp. I'm curious.
Re: results of added compression to 511 [Re: mopar dave] #2780172
05/31/20 08:21 PM
05/31/20 08:21 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
A lot of fuel is used in the drive up/back and the burnout
Re: results of added compression to 511 [Re: mopar dave] #2780181
05/31/20 08:44 PM
05/31/20 08:44 PM
AndyF Online content
AndyF  Online Content
You are probably around 650 crank hp these days. Might have picked up 40 or 50 hp from the change. 134 mph is fast enough to dip into the 9's. Probably just need to find a little more traction off the line or change the launch process. It is still a street driver right? So you are probably limited on how radical you can get with the chassis and launch.
Re: results of added compression to 511 [Re: AndyF] #2780186
05/31/20 08:53 PM
05/31/20 08:53 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, street/strip all the way, mostly street. I think its a high 9 car, just need to find it. Gonna keep pushin on for 700hp. Indy tunnel ram is next then a more aggressive cam.
Re: results of added compression to 511 [Re: Clanton] #2780190
05/31/20 08:58 PM
05/31/20 08:58 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah, it burns some fuel for sure. Went with over a half tank and thought it would be enough. Oh and this 12.5:1 compression motor runs on 98 octane with no sign of detonation. Timing was left at 36*. I had penty of engine builders telling me it needs 110 all the time. Don't let anyone fool you, IMO 110 isn't needed with 12.5:1 in a 511 with under 7000rpm usage. I think there are many racers out there leaving power on the table by over octaning. I may get away with 96 octane. I'll let ya know.
Re: results of added compression to 511 [Re: mopar dave] #2780198
05/31/20 09:33 PM
05/31/20 09:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My small block is 11.2-1, it made 30 more hp on pump 93 than 98 race gas on a engine dyno.
Re: results of added compression to 511 [Re: justinp61] #2780202
05/31/20 09:44 PM
05/31/20 09:44 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Awesome results, that's quite an improvement.
Re: results of added compression to 511 [Re: justinp61] #2780219
05/31/20 10:56 PM
05/31/20 10:56 PM
Mt Morris Michigan
Mt Morris Michigan
Yes my 11.25 408 was fastest on straight pump gas.
Re: results of added compression to 511 [Re: mopar dave] #2780244
06/01/20 05:48 AM
06/01/20 05:48 AM
UK
rb446 Offline
rb446  Offline
UK
Nice run, 662fwhp>
60 Foot E.T. : 1.39
1/8 Mile E.T. : 6.33
1/8 Mile Trap Speed : 107.40
1/4 Mile E.T. : 10.03
1/4 Mile Trap Speed : 134 up
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: results of added compression to 511 [Re: rb446] #2780250
06/01/20 07:21 AM
06/01/20 07:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Making the assumption that the earlier runs were at Milan on 9-1-2019. The D/A yesterday from 10-4 ranged 254-1223. The previous date at the same times1284-1873. So some of your improvements were due to weather. A gain none the less. As far as fuel consumption. Last week a Mid Michigan we made 9 passes. Used just under 5 gallons. This weekend at Dragway 42 we were pitted at the end of the track. The runs were over a 2 day period. The run times were further apart. This entailed more warm up. 7 passes 5 gallons.
Doug
Re: results of added compression to 511 [Re: mopar dave] #2780260
06/01/20 08:18 AM
06/01/20 08:18 AM
Mt Morris Michigan
Mt Morris Michigan
I can think of a few things that I could have done while there that may have put me into the 9 zone. One would be tighten up the rear shock because the separation is huge, two would be putting the wilsons 4 hole tapered spacer on and three, set my shift lite on 62 or 6300 so it gets shifted by 6600. I was a bit slow on the draw. Here’s the next project.
Re: results of added compression to 511 [Re: dvw] #2780265
06/01/20 08:32 AM
06/01/20 08:32 AM
Mt Morris Michigan
Mt Morris Michigan
Yes and no. I ran at Mid Michigan the weekend before I went to Milan, so two weeks in a row, but MM was first and the air seemed to be just as good as this past Saturday. Please check the weather on Aug 30 2019 at 9.37PM. That was the time of the 10.401@129.75 pass. Thanks
I ran that weekend without the mechanical fan, then I put the mechanical fan on and went to Milan the next weelend to see what HP it would cost me, but the weather sucked and I lost 2 tenths and 2mph. I'm thinking the weather cost me a tenth and the fan another tenth.
Re: results of added compression to 511 [Re: mopar dave] #2780275
06/01/20 09:12 AM
06/01/20 09:12 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I don’t know how you test n tuners test n tune without your own equipment to check air conditions. Online corrected conditions only tell part of the story.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: results of added compression to 511 [Re: mopar dave] #2780277
06/01/20 09:15 AM
06/01/20 09:15 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
About 640-
My W5 deal weighed 3350 and went 135, figured it for 640 too
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: results of added compression to 511 [Re: pittsburghracer] #2780278
06/01/20 09:16 AM
06/01/20 09:16 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thats a GREAT point
Re: results of added compression to 511 [Re: B3422W5] #2780279
06/01/20 09:20 AM
06/01/20 09:20 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks for the info Don. I was at MM one weekend when you were there with your old car, seen it run. It is a bad ass for sure small block.
Re: results of added compression to 511 [Re: mopar dave] #2780290
06/01/20 10:34 AM
06/01/20 10:34 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My guess is once your combo settles in, it will run in the 9.80’s with a little tweeking
Its really coming around
Out of curiousity, what convertor and where does it flash
1.41 best 60 foot
6.56 at 104.17
Re: results of added compression to 511 [Re: B3422W5] #2780293
06/01/20 11:10 AM
06/01/20 11:10 AM
Mt Morris Michigan
Mt Morris Michigan
Vert is an 8” Dynamic refreshed by Lenny. Flashes 5400.
Re: results of added compression to 511 [Re: mopar dave] #2780359
06/01/20 02:32 PM
06/01/20 02:32 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Nice up big difference what compressing ratio did buddy of mine just put together a 424 SB with 10.50 C/R with a big cam told him good luck it will be a dog.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: results of added compression to 511 [Re: JD Dart] #2780367
06/01/20 02:47 PM
06/01/20 02:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
my 416 is 10:1 with a 272@.050 .658 lift at the valve solid roller. Runs on 91 octane and has been 10.54 in a 3550lb street car. But I agree more compression is usually always better.
68 Barracuda Formula S 340
Page 2 of 3 1 2 3
