'66 Belvedere at the track #2692772
08/30/19 12:54 AM
08/30/19 12:54 AM
AndyF Offline OP
AndyF  Offline OP
This is a car that a couple of local guys built this year. It was a stock Belvedere last winter then they pulled it into the shop and fired up the tools. I don't have many pictures of it but it came out looking super nice. I supplied a few parts and helped tune the EFI system. It has a 505 with TF 270 heads. Should run mid 9's once it gets sorted out.
Re: '66 Belvedere at the track [Re: AndyF] #2692773
08/30/19 12:58 AM
08/30/19 12:58 AM
AndyF Offline OP
AndyF  Offline OP
Here is a picture taken back in Jan of this year. This was right before they started to pull the car apart.
Re: '66 Belvedere at the track [Re: AndyF] #2692788
08/30/19 03:35 AM
08/30/19 03:35 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Neat car. Too bad about the solid axle.
Re: '66 Belvedere at the track [Re: Jeremiah] #2692940
08/30/19 03:27 PM
08/30/19 03:27 PM
AndyF Offline OP
AndyF  Offline OP
They run the car in a NHRA Gas Eliminator class so that is the look they wanted. The car looks pretty cool and it goes down the track really nice. I did the tune on the EFI system and so far it is working great. They ran the car at sea level then the next track they were at had a DA of 4500 feet. They didn't have to touch the car, the EFI system handled all of the tuning changes just fine. They have run a few races now without even needing to open the hood. Just fill it with gas and go rounds.
Re: '66 Belvedere at the track [Re: AndyF] #2693099
08/31/19 09:43 AM
08/31/19 09:43 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That pic reminded me that it's been 40 years since I raced at Woodburn... eek
Re: '66 Belvedere at the track [Re: BradH] #2693141
08/31/19 12:53 PM
08/31/19 12:53 PM
AndyF Offline OP
AndyF  Offline OP
They still have a big sign at the starting line that says "BradH raced here".
Re: '66 Belvedere at the track [Re: AndyF] #2693150
08/31/19 01:31 PM
08/31/19 01:31 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Lmao!
'63 Dodge 330
11.19 @ 121 mph
Re: '66 Belvedere at the track [Re: GY3] #2693188
08/31/19 03:57 PM
08/31/19 03:57 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
That has to be a weird class... straight axle gasser style cars with...... EFI... not real consistent with a nostalgia deal...
Re: '66 Belvedere at the track [Re: AndyF] #2693197
08/31/19 04:57 PM
08/31/19 04:57 PM
BradH Offline
BradH  Offline
Hmmm... it was supposed to say: "BradH won here... once." tonguue
Re: '66 Belvedere at the track [Re: AndyF] #2693291
08/31/19 10:57 PM
08/31/19 10:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That is cool if they are into it. It could always be put back to torsion bars I would imagine. The EFI stuff is amazing. I like not having to open the hood.
Re: '66 Belvedere at the track [Re: Jeremiah] #2694929
09/06/19 11:09 AM
09/06/19 11:09 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Cool! any pics of how it sits statically? I've been contemplating a straight axle under my 66.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: '66 Belvedere at the track [Re: OUTLAWD] #2694936
09/06/19 11:24 AM
09/06/19 11:24 AM
AndyF Offline OP
AndyF  Offline OP
No I don't have any other pictures. I think the nose is slightly higher than the tail when the car is parked but it isn't a huge amount. Maybe an inch taller up front. The front has to sit high since the straight axle gets close to the oil pan. If I was going to build one of these cars I'd use a front axle with a little bit of drop in it. Even a two inch drop would help provide some oil pan clearance.
Re: '66 Belvedere at the track [Re: AndyF] #2780122
05/31/20 05:48 PM
05/31/20 05:48 PM
AndyF Offline OP
AndyF  Offline OP
The track was open for test and tune today so I went down to help with the Belvedere. It had slowed down a little bit from where it had been running so they wanted my help to look things over. Eventually we figured out that the throttle linkage had backed itself off a bit and the throttle blades were not opening all the way. Once that was fixed it ran 9.84 at 134 mph. Fun ride for the guy. Engine is a 505 with TF 270 heads, solid roller with a Holley EFI setup.
Re: '66 Belvedere at the track [Re: Jeremiah] #2780180
05/31/20 08:44 PM
05/31/20 08:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yea, what’s that all about?
Re: '66 Belvedere at the track [Re: cudaman1969] #2780184
05/31/20 08:47 PM
05/31/20 08:47 PM
AndyF Offline OP
AndyF  Offline OP
Just what he likes I guess. He has some other gasser type cars as well as a super nice '56 Chevy. The Chevy was there today and it was moving. I saw it run a couple of passes at 141 mph and 142 mph. I'm not really used to seeing a '56 Chevy go by at 142 mph!
Re: '66 Belvedere at the track [Re: AndyF] #2781267
06/03/20 11:45 PM
06/03/20 11:45 PM
California, U.S.A.
Torquemonster440 Offline
California, U.S.A.
Not a fan of the straight axle on this body style. Maybe a 64 or 65 perhaps. I own a 66 myself and knew it was not the look I wanted for this body style. Although I do want it to be somewhat period correct. My Dad is in the process of making the straight axle swap on his '55 Chevy and I'm stoked ! Call me closed minded, but that looks just belongs on those cars. That's how they were done back in the day.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: '66 Belvedere at the track [Re: Torquemonster440] #2785509
06/14/20 08:36 PM
06/14/20 08:36 PM
AndyF Offline OP
AndyF  Offline OP
Went to the track today with the guys who own the Belvedere. It was running pretty tight grouping, 9.88, 9.87, 9.89, etc. Speed is 135 mph with the 3.88 gears.
Re: '66 Belvedere at the track [Re: AndyF] #2785511
06/14/20 08:39 PM
06/14/20 08:39 PM
AndyF Offline OP
AndyF  Offline OP
Here is a picture of his brother's Chevy (the silver one). The shoebox runs 140+ mph. I also snapped a picture of a '65 Coronet 500 since I own a '65 Coronet 500. I talked to the guy a little bit. I think it was a stock stroke 440 with Edelbrock heads but I didn't talk to him to much. He was busy chasing some sort of mechanical problem.
Re: '66 Belvedere at the track [Re: AndyF] #2785591
06/15/20 07:14 AM
06/15/20 07:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice! Looks like your acclimated with the track enough to get that Duster out now!
68 Barracuda Formula S 340
Re: '66 Belvedere at the track [Re: AndyF] #2785594
06/15/20 07:45 AM
06/15/20 07:45 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Given the current state of affairs, maybe consider adding WU to the graphics, works both ways
