Re: results of added compression to 511
[Re: justinp61]
#2780202
05/31/20 09:44 PM
05/31/20 09:44 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Awesome results, that's quite an improvement.
[Re: mopar dave]
#2780244
06/01/20 05:48 AM
06/01/20 05:48 AM
Posts: 570 UK
rb446
UK
Race weight is 3380. I'm gonna have to check Wallace calculators for hp. I'm curious. Nice run, 662fwhp> 60 Foot E.T. : 1.39 1/8 Mile E.T. : 6.33 1/8 Mile Trap Speed : 107.40 1/4 Mile E.T. : 10.03 1/4 Mile Trap Speed : 134 ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: mopar dave]
#2780260
06/01/20 08:18 AM
06/01/20 08:18 AM
Posts: 8,046 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I can think of a few things that I could have done while there that may have put me into the 9 zone. One would be tighten up the rear shock because the separation is huge, two would be putting the wilsons 4 hole tapered spacer on and three, set my shift lite on 62 or 6300 so it gets shifted by 6600. I was a bit slow on the draw. Here’s the next project.
[Re: dvw]
#2780265
06/01/20 08:32 AM
06/01/20 08:32 AM
mopar dave
Mt Morris Michigan
Yes and no. I ran at Mid Michigan the weekend before I went to Milan, so two weeks in a row, but MM was first and the air seemed to be just as good as this past Saturday. Please check the weather on Aug 30 2019 at 9.37PM. That was the time of the 10.401@129.75 pass. Thanks I ran that weekend without the mechanical fan, then I put the mechanical fan on and went to Milan the next weelend to see what HP it would cost me, but the weather sucked and I lost 2 tenths and 2mph. I'm thinking the weather cost me a tenth and the fan another tenth.
[Re: mopar dave]
#2780275
06/01/20 09:12 AM
06/01/20 09:12 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don’t know how you test n tuners test n tune without your own equipment to check air conditions. Online corrected conditions only tell part of the story.
[Re: mopar dave]
#2780277
06/01/20 09:15 AM
06/01/20 09:15 AM
Posts: 11,730 Portage,michigan
B3422W5
Portage,michigan
Race weight is 3380. I'm gonna have to check Wallace calculators for hp. I'm curious. About 640- My W5 deal weighed 3350 and went 135, figured it for 640 too
[Re: pittsburghracer]
#2780278
06/01/20 09:16 AM
06/01/20 09:16 AM
Posts: 2,876 Pattison Texas
CSK
Pattison Texas
I don’t know how you test n tuners test n tune without your own equipment to check air conditions. Online corrected conditions only tell part of the story. Thats a GREAT point
[Re: mopar dave]
#2780290
06/01/20 10:34 AM
06/01/20 10:34 AM
B3422W5
Portage,michigan
Ok, thanks for the info Don. I was at MM one weekend when you were there with your old car, seen it run. It is a bad ass for sure small block. My guess is once your combo settles in, it will run in the 9.80’s with a little tweeking Its really coming around Out of curiousity, what convertor and where does it flash
[Re: mopar dave]
#2780359
06/01/20 02:32 PM
06/01/20 02:32 PM
Posts: 740 WA
JD Dart
WA
Nice ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) big difference what compressing ratio did buddy of mine just put together a 424 SB with 10.50 C/R with a big cam told him good luck it will be a dog.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: JD Dart]
#2780367
06/01/20 02:47 PM
06/01/20 02:47 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Nice ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) big difference what compressing ratio did buddy of mine just put together a 424 SB with 10.50 C/R with a big cam told him good luck it will be a dog. my 416 is 10:1 with a 272@.050 .658 lift at the valve solid roller. Runs on 91 octane and has been 10.54 in a 3550lb street car. But I agree more compression is usually always better.
68 Barracuda Formula S 340
