Re: trunk weatherstrip
[Re: moparthunder70]
#2779572
05/29/20 06:45 PM
05/29/20 06:45 PM
Posts: 20,594 So Near, Yet So Far
topside
So Near, Yet So Far
True about compression, that's usually the case on trunk lids, and most doors, especially early B bodies. Adjust the latch up, close the lid, and it'll help compress the seal.
Now, if you're saying that the problem is only on one side: Either a panel or its seal flange are incorrect. You can adjust that in most cases by bending that flange down to gain more room for the seal's height. That can be tricky; it's easier to do before gluing the seal on, and you have to be careful with the paint. Is that the issue ?
