headers #2779175
05/28/20 05:44 PM
05/28/20 05:44 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
who make the best header for 5.7 hemi to fit in a 72 duster
Re: headers [Re: duspan] #2779396
05/29/20 10:47 AM
05/29/20 10:47 AM
K
Kiddart Offline
Kiddart  Offline
K
that's a loaded question.
there are the exhaust manifolds from the 09-10 Jeep manifolds actually work but tight. see this thread on for a bodies only. https://www.forabodiesonly.com/mopar/threads/73-scamp-5-7-swap.423219/
TTI is going to be the no brainier but get ready to spend a load of cash I went tti way non coated then did my own ceramic coating spray on and so far they are good, they fit awesome with Manual steering. but get ready to spend a few hours putting them in. Its a [censored] bolting them on after the motor is in the engine compartment. if you can and have the means drop the front k- member, assemble the motor and trans with headers then reinstall. if you cant do that its ok you will just be bending and using swear words you never new. its fun but takes time and patience.
there are a lot of options with TTI that's why I said loaded question. see link to TTI
https://www.ttiexhaust.com/MoparClassics-Headers/Subcategory/ccGen3.htm
Thank you
Kiddart
Re: headers [Re: Kiddart] #2779485
05/29/20 02:30 PM
05/29/20 02:30 PM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
I went the TTI header route after the advice of others who have done this. You do get what you pay for and they are really well made.
I was just trying to decide whether to put the engine in from the top and then headers from the bottom OR drop the K frame and put it all together and lower the car on. We have a 2 post lift too. Great timing on your post 392, I think I will be dropping the K frame now. I'm not a fan of scratching up stuff either.
Re: headers [Re: duspan] #2779547
05/29/20 05:32 PM
05/29/20 05:32 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
What's unique about the 09-10 jeep manifolds? Curious because the 6.4 truck manifolds I have left over from my engine look real close to the pics in the thread, also hugging the block up close.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: headers [Re: A39Coronet] #2780365
06/01/20 02:45 PM
06/01/20 02:45 PM
K
Kiddart Offline
Kiddart  Offline
K
the one in your picture will exit right into your firewall, the ones for the jeep Cherokee both sides exit angled down just before the separation point of the motor and trans. they are still tricky to get the pipe in and the nuts started but very doable for sure. you may have to do some creative downpipe work.
Thank you
Kiddart
Re: headers [Re: Kiddart] #2798668
07/19/20 06:39 PM
07/19/20 06:39 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Will headers from a modern hemi car fit an older car or truck?
Re: headers [Re: duspan] #2798703
07/19/20 08:09 PM
07/19/20 08:09 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Headers, I'm not sure. Manifolds seem to be hit or miss. The jeep headers seem to work on select front ends, based on the rabbit hole from the link above. I still think the manifolds I posted can be a solution for some, as they won't direct the pipe into the torsion bar.
Only one way to find out though, buy a cheap set and giver hell
