Break in oil.. Zinc? #2779363
05/29/20 08:51 AM
05/29/20 08:51 AM
Columbus, Ohio
Chally426 Offline OP
Columbus, Ohio
What's the best oil to run in our old motors? What's a good break in oil? Does it need to be high in Zinc, Someone said Diesel oil was good because of the zinc and it was cheaper
Thoughts?
Re: Break in oil.. Zinc? [Re: Chally426] #2779368
05/29/20 08:59 AM
05/29/20 08:59 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Thoughts?
I use Brad Penn or now Penn1 green oil. Break in 30w
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Break in oil.. Zinc? [Re: VCODE] #2779370
05/29/20 09:03 AM
05/29/20 09:03 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
The amount of zinc in diesel oil has been reduced over the last few years
1969 Hemi Roadrunner 2nd owner
Re: Break in oil.. Zinc? [Re: Chally426] #2779371
05/29/20 09:06 AM
05/29/20 09:06 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Was a Brad Penn fan until they changed the formula now I only use Joe Gibbs racing oil. They have a nice formula for break in that you can leave in for a few hundred miles to insure a good break in. Then you can replace it with their Hot Rod oil designed for flat tappet cams.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Break in oil.. Zinc? [Re: fourgearsavoy] #2779372
05/29/20 09:11 AM
05/29/20 09:11 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
I heard Joe Gibbs is good also.
And VR1 valvoline
Bob
Re: Break in oil.. Zinc? [Re: fourgearsavoy] #2779375
05/29/20 09:25 AM
05/29/20 09:25 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Gus beer
I am now using the Gibbs oil as well. Had my 440 dynoed and that is what the engine builder recommended to me.
BR40 for break in and GR5 afterwards.
I also chose their GL-4 gear oil for m 18 spline trans.
Link
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Break in oil.. Zinc? [Re: 70gtx440dana] #2779389
05/29/20 10:23 AM
05/29/20 10:23 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used the Gibbs and Lucas oils in FT & race engines, both have been fine.
Local circle-track engine guru switched from Gibbs to Lucas, saying it tests more consistently.
He's currently testing VR1's oil.
Re: Break in oil.. Zinc? [Re: topside] #2779468
05/29/20 01:28 PM
05/29/20 01:28 PM
md
mopars4ever Offline
mopars4ever  Offline
md
For my old stuff with a flat tappet I have been using the Lucas hot rod oil on my last few oil changes. I have also used Valvoline VR1 in the past.
I can`t remember what I used for break in oil.
Re: Break in oil.. Zinc? [Re: mopars4ever] #2779479
05/29/20 02:11 PM
05/29/20 02:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I run the Shell RotellaT 15W-40 in my gas and diesels.
Re: Break in oil.. Zinc? [Re: 69hemibeep] #2779548
05/29/20 05:37 PM
05/29/20 05:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Not in Shell Rotella.
Re: Break in oil.. Zinc? [Re: Chally426] #2779755
05/30/20 01:29 PM
05/30/20 01:29 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
You might want to research JR1 Racing Oils. Quite a few NHRA and IHRA drag racers use their products.
Re: Break in oil.. Zinc? [Re: NITROUSN] #2779760
05/30/20 01:34 PM
05/30/20 01:34 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It has actually but is still over 1000 ppm on the last oil analysis I saw. Bobistheoilguy usually has fairly current reports in their heavy duty engine oil forum.
If you really want to know, go to Walmart and buy a quart of Rotella and for comparison, a quart of the store brand 15w40 and then go to a Kenworth or other heavy truck dealer and purchase two oil analysis kits and send in a sample of each. Should cost you about $50 total +/- and then you KNOW what you're getting. Unless you are approaching roller spring pressures, anything in the 1000 ppm will be fine. Chances are the Walmart brand will test as good or better than the Rotella.
Kevin
Re: Break in oil.. Zinc? [Re: Twostick] #2779765
05/30/20 01:44 PM
05/30/20 01:44 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Here's an analysis of Rotella T5 15w40 non synthetic I found on Bobistheoilguy from February this year.
Kevin
Re: Break in oil.. Zinc? [Re: Twostick] #2779766
05/30/20 01:49 PM
05/30/20 01:49 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Here's a 10w30 T5 Rotella.
Kevin
Re: Break in oil.. Zinc? [Re: Twostick] #2779767
05/30/20 01:52 PM
05/30/20 01:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I just received my answer direct from shell. Here is what I was told.
Case No: 00116431
Enquiry: Rotella t
Response:
Hello,
Trust you are well. We have not reduced the zinc content of our Rotella Oils -all of the Rotella Multigrade oils (with the exception of Rotella Multi-vehicle 5W-30) still contains approximately 1200 ppm of zinc and 1100 ppm of phosphorus which is suitable for flat tappet engine application especially those that require high zinc oil.
Hope this helps. Stay safe
Re: Break in oil.. Zinc? [Re: NITROUSN] #2779773
05/30/20 02:18 PM
05/30/20 02:18 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The Blackstone analysis confirms that. up
Kevin
Re: Break in oil.. Zinc? [Re: NITROUSN] #2779780
05/30/20 02:59 PM
05/30/20 02:59 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Case No: 00116431
Enquiry: Rotella t
Response:
Hello,
This is why I run Shell Rotella T6 syn 5W40 in my wet clutch motorcycles that have shim-bucket slider cams. Its JASO-MA2 rating is good for most water cooled bikes. The 15W40 is good for most Air cooled bikes.
Stolen from BITOG, a member on here posted it there.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Break in oil.. Zinc? [Re: Dave_J] #2779944
05/31/20 06:30 AM
05/31/20 06:30 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
What is a good number to shoot for as far as zinc content? I see Valvoline 10w30 is 760 for zinc and 690 for phosphorous, Valvoline VR1 10w30 is 1400 for zinc and 1300 for Phosphorous, and Shell Rotella T5 10w30 is 1085 for zinc and 989 for phosphorous. Not a fan of synthetic myself, prefer to stick to conventional. Looks like T5 is synthetic. Currently using VR1, but shell seems cheaper.
Re: Break in oil.. Zinc? [Re: MI_Custumz] #2779960
05/31/20 08:28 AM
05/31/20 08:28 AM
BDW Online content
BDW  Online Content
Don’t waste money on those speciality oils, get some Lucas break-in additive and the Walmart oil.
1/3 of a bottle, and a oil change will cost you <$20 including filter.
Re: Break in oil.. Zinc? [Re: BDW] #2779997
05/31/20 10:31 AM
05/31/20 10:31 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
There are potential problems with using zinc additives... how do you ensure that it's fully mixed before starting the engine? work
I could see several seconds (or minutes) before the bottle is completely mixed with the 5-8 quarts of oil and has at least 1000 ppm throughout, even if you pour it in first.
Meanwhile, what's happening to your cam/lifter interface?
