Re: Break in oil.. Zinc?
[Re: Chally426]
#2779368
05/29/20 08:59 AM
05/29/20 08:59 AM
Posts: 2,377 White Plains, NY
VCODE
White Plains, NY
What's the best oil to run in our old motors? What's a good break in oil? Does it need to be high in Zinc, Someone said Diesel oil was good because of the zinc and it was cheaper
Thoughts? I use Brad Penn or now Penn1 green oil. Break in 30w Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#2779370
05/29/20 09:03 AM
05/29/20 09:03 AM
Posts: 1,383 Az
69hemibeep
Az
The amount of zinc in diesel oil has been reduced over the last few years
1969 Hemi Roadrunner 2nd owner
[Re: Chally426]
#2779371
05/29/20 09:06 AM
05/29/20 09:06 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Was a Brad Penn fan until they changed the formula now I only use Joe Gibbs racing oil. They have a nice formula for break in that you can leave in for a few hundred miles to insure a good break in. Then you can replace it with their Hot Rod oil designed for flat tappet cams. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2779372
05/29/20 09:11 AM
05/29/20 09:11 AM
VCODE
White Plains, NY
I heard Joe Gibbs is good also. And VR1 valvoline Bob
[Re: fourgearsavoy]
#2779375
05/29/20 09:25 AM
05/29/20 09:25 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Was a Brad Penn fan until they changed the formula now I only use Joe Gibbs racing oil. They have a nice formula for break in that you can leave in for a few hundred miles to insure a good break in. Then you can replace it with their Hot Rod oil designed for flat tappet cams. Gus I am now using the Gibbs oil as well. Had my 440 dynoed and that is what the engine builder recommended to me. BR40 for break in and GR5 afterwards. I also chose their GL-4 gear oil for m 18 spline trans. Link
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: Chally426]
#2779755
05/30/20 01:29 PM
05/30/20 01:29 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
You might want to research JR1 Racing Oils. Quite a few NHRA and IHRA drag racers use their products.
[Re: NITROUSN]
#2779760
05/30/20 01:34 PM
05/30/20 01:34 PM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
The amount of zinc in diesel oil has been reduced over the last few years Not in Shell Rotella. It has actually but is still over 1000 ppm on the last oil analysis I saw. Bobistheoilguy usually has fairly current reports in their heavy duty engine oil forum. If you really want to know, go to Walmart and buy a quart of Rotella and for comparison, a quart of the store brand 15w40 and then go to a Kenworth or other heavy truck dealer and purchase two oil analysis kits and send in a sample of each. Should cost you about $50 total +/- and then you KNOW what you're getting. Unless you are approaching roller spring pressures, anything in the 1000 ppm will be fine. Chances are the Walmart brand will test as good or better than the Rotella. Kevin
[Re: NITROUSN]
#2779780
05/30/20 02:59 PM
05/30/20 02:59 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I just received my answer direct from shell. Here is what I was told.
Case No: 00116431 Enquiry: Rotella t Response:
Hello,
Trust you are well. We have not reduced the zinc content of our Rotella Oils -all of the Rotella Multigrade oils (with the exception of Rotella Multi-vehicle 5W-30) still contains approximately 1200 ppm of zinc and 1100 ppm of phosphorus which is suitable for flat tappet engine application especially those that require high zinc oil.
Hope this helps. Stay safe This is why I run Shell Rotella T6 syn 5W40 in my wet clutch motorcycles that have shim-bucket slider cams. Its JASO-MA2 rating is good for most water cooled bikes. The 15W40 is good for most Air cooled bikes. Stolen from BITOG, a member on here posted it there.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: BDW]
#2779997
05/31/20 10:31 AM
05/31/20 10:31 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
There are potential problems with using zinc additives... how do you ensure that it's fully mixed before starting the engine? I could see several seconds (or minutes) before the bottle is completely mixed with the 5-8 quarts of oil and has at least 1000 ppm throughout, even if you pour it in first. Meanwhile, what's happening to your cam/lifter interface?
